Pls help lol
laynalicious
Hey,
So I am looking to buy a PC to use for playing Fortnite and to stream it.
I've had a few people help me pick a spec but it's turned into a too many cooks in the kitchen situation.
I've looked at the pre-builts and what my friends have suggested, and cooked up the below:
LIAN LI LANCOOL II GAMING CASE
ASUS® ROG STRIX B450-F GAMING II (DDR4, USB 3.1, 6Gb/s) - RGB Ready!
16GB PCS PRO DDR4 2666MHz (2 x 8GB)
12GB AMD RADEON™ RX 6700 XT - HDMI, DP - DX® 12
PCS FrostFlow 100 V3 Series High Performance CPU Cooler (AMD)
LED Lighting
50cm ARGB LED Strip
Norton 360 For Gamers - Free 90 Day License
Promotional Item
Get up to 3 games with qualifying AMD Radeon RX 6000 GPUs!
Welcome Book
Logo Branding
PCSpecialist Logo
Would this be an ideal spec to work with for gaming, streaming and have it last a good few months before any upgrades?
Looking at an investment here, as I'm sick of my PS4 lol
Thank you <3
MrWilson
Godlike
Hi there,
The spec isn't ideal I'm afraid, it's got a weak motherboard, RAM, cooler and PSU among other areas. I know that we can spec you something better.
To help us spec something more appropriate please could you let us know your budget, and the monitor you are pairing this with (make and model or resolution and refresh rate) and we can spec something to fit those requirements.
laynalicious
Hi there,
Hey! thanks for your response.
Budget is around £1400, the monitor I'm getting (exc. from budget price) is AOC 24G2 23.8" 1920x1080 144 Hz Monitor.
sck451
For those purposes and that budget, here's what I'd personally suggest. Save a bit on the CPU and graphics card, and make an overall stronger build out of it.
If you can find an extra £75, a CPU upgrade to the 5700X would be perfectly worthwhile.
512GB INTEL® 670p M.2 NVMe PCIe SSD (up to 3000MB/sR, 1600MB/sW)
1TB PCS PCIe M.2 SSD (2200 MB/R, 1500 MB/W)
PCS FrostFlow 150 Series High Performance CPU Cooler
Microsoft® Edge
Price: £1,402.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/77FrcXmwyn/
MrWilson
Godlike
Apologies, I got distracted after the initial post. Build from @sck451 is great though, makes the most of your budget. Upgrading to the 5700X CPU would be ideal but as Fortnite isn’t massively demanding sticking with the 5600X should be fine as well.
