Richard911
Hi all
I recently purchased a Cosmos II 17.3" laptop with Win7.
The built in microphone has fairly poor quality sound. When its used with skype the sound is distant and indistinct.
I wanted to check I'm using the best available drivers and settings.
When I click start, computer, manage, device manager, sound video and game controllers. I see :-
Bluetooth Audio Device
NVIDIA Virtual audio device (Wave Extensible) (WDM)
VIA High Definition Audio
Which of these is the built in microphone ?
What driver should it have (provider, date, version) ?
When I click start, control panel, hardware and sound, sound, recording, microphone, properties, levels.
I see Microphone set to 100 and Microphone Boost set to +30.dB.
When I click Advanced I see.
2 channel, 24 bit, 48000 Hz (studio Quality)
Allow applications to take exclusive control of this device is enabled.
Give exclusive mode applications priority is enabled.
Should I change the above settings or are they as good as they can be ?
Are there any other settings that are important ?
Thanks
Richard
Thanks
Richard
