So I used to get power disconnects with this laptop. Just straight after playing a game 5 for 10 minutes sometimes 30 minutes. Or when put up a stress test like furmark, pretty much instantly.
And in a few occasions even when just browsing the internet.
-Nvidia display driver lost level 3 error
-Processor state limited by firmware event id 37
Now my friend soldered a new VRM on my 980m and the power outages COMPLETELY stopped when running furmark or anything really. So I was happy and thought it was fixed. I run 6 hours Heaven Benchmark, and 2 hours furmark. Ran perfectly fine without a single freeze, crash or power outage. We have more VRM's for the GPU card but we haven't added extra ones then the one we replaced (which might help with stabillity we read) and are not sure it would help with the problem, but it is still something we could try.
So It was curious for me to find out, when I started playing games again, that the game is still freezing. giving me those errors in the windows log. about nvidia display driver lost and processor speed.
Eventhough the game (I test with rune terra) is really not taxing 10-25% cpu and 4% gpu and 0.5 GB Vram in use. And im sure by now this is not a specific game issue.
When this happens the image is just frozen in the screen and does not move, but I can use alt tab.
I tried using TDR manipulator to increase TDRlevel.. but that didn't help unfortunately.
So what my friend did ,definitely helped. but it didn't completely fix the problem.
Some things I read on google:
"The "Speed of processor 0 in group is being limited by system firmware" warning message in event log, is commonly caused from Intel(R) SpeedStep Technology. Intel SpeedStep Technology, reduces the clock speed of your processor whenever your processor is idle, in order to reduce power consumption and heating"
"The speed of processor 0 in group 0 is being limited by system firmware. ... may be drawing excessive power or otherwise disrupting proper voltage regulation"
"Kernel-Processor-Power Event ID 37 is not an error, it is a warning. It informs you that your system runs on low battery and therefore has reduced the speed."
Some screenshots of my windows error logs
http://prntscr.com/rbw3s0
http://prntscr.com/rbw3wg
http://prntscr.com/rbw42a
http://prntscr.com/rbw46d
We are at a complete loss what to do next.
I hope you can give some tips on what to try.
My friend says it is likely still a power issue, caused by powersupply or VRM.
So one thing we would like to know is, what VRM (voltage regulator module) are used for the mainboard of P771DM-G.
Is that info you could provide us with, so we can resolder VRM's to the mainboard?
Tried looking into this, but it doesn't seem you can make out of it, what VRM's are used.
http://www.e-weekly.co.uk/download/RnD/DRIVERS/CLEVO/P7x0DM/P77DM_ESM.pdf
I don't think the entire GPU would need to be replaced. But I think it is power components around it that make it produce errors.
Because I also get messages about processor speed being limited I think the problem is much bigger/different then just a broken GPU card.
On a side note my bios is 1.05.04 system bios date 10/05/2015 video bios date 08/10/15
I haven't seen any updates for my laptop. But I don't think it would help with the problem im facing anyway.
