Problem with CPU Fan
ASUS® TUF GAMING B460-PLUS, i7 Intel® Core™ i7-10700KF, DDR4 Corsair VENGEANCE 2400 MHz 16 GB (2 da 8 GB), NVIDIA GEFORCE GTX 1650 4 GB – HDMI, SAMSUNG 970 EVO PLUS M.2 500 GB
Good evening, after about a month of using my new desktop PC without any problems, configuration made using the configurator on the PcSpecialist site, it is a couple of days that the CPU fan started with an annoying noise, sometimes it is continuous, sometimes it is intermittent. Have you had any such problems? Thanks.
Stefano
Thanks for reply, this is the spec and in attach the noise (when i recorded the noise the pc was idle; when play a game the noise is the same):
Processore (CPU)Processore i7 Intel® Core™ i7-10700KF 8 core (3,8 GHz) 16 MB cache
Scheda madreASUS® TUF GAMING B460-PLUS: ATX, LGA1200, USB 3.2, SATA 6 GBs -
RGB-ready
Memoria (RAM)DDR4 Corsair VENGEANCE 2400 MHz 16 GB (2 da 8 GB)
Scheda graficaNVIDIA GEFORCE GTX 1650 4 GB – HDMI
1o Unità di archiviazioneNOT REQUIRED
1o drive SSD M.2SAMSUNG 970 EVO PLUS M.2 500 GB, NVMe PCIe (fino a 3500 MB/R,
3200 MB/W)
Unità DVD/BLU-RAYNOT REQUIRED
AlimentatoreALIMENTATORE CORSAIR 450 W CV SERIES™ VS-450
Cavo di alimentazione1 cavo di alimentazione europeo 1 metro (tipo kettle)
Raffreddamento processoreDissipatore CPU PCS FrostFlow 100 RGB Series ad alte prestazioni
Pasta termicaPASTA TERMICA STANDARD PER UN RAFFREDDAMENTO SUFFICIENTE
Scheda audioAUDIO ALTA DEFINIZIONE INTEGRATO A 6 CANALI (5.1) (DI SERIE)
Scheda di retePORTA LAN GIGABIT 10/100/1000 (Wi-Fi NON INCLUSO)
Opzioni USB/ThunderboltMIN. 2 PORTE USB 3.0 & 2 PORTE USB 2.0 @ PANNELLO SUL RETRO +
MIN. 2 PORTE FRONTALI
Thanks!
  • WhatsApp Audio.zip
is the one suggested in the configurator
It was in the list of available for that cpu.
The configurator can’t tell you how to spec a machine, it just lists the parts that fit that chipset. You’re expected to know how to design the pc and if you don’t know, then you need to get advice.
that cooler is not going to work on that CPU, it will be running at full tilt constantly and it’s not designed to do that at all and will fail quickly.
