Dear pc specialist.
Finally opened my new mini pc and was delighted, until I took the top off to check there was no padding inside the case and found the sheath around the psu cables torn and the cable management left half the cables flapping around inside. After securing the others and finally connecting it up, imagine my delight then when it was idling with the fan on full. Curious I installed a temp monitor and found cores 1 & 2 at 99 and I20c with 4% load. so I cracked open the case again and found the pump for the water cooler was connected wrong so no power was running to it. I have now fixed this and it doesn't sound like a rolls Royce turbojet, I'm just hoping the cpu hasn't been damaged.
Whoever did the build and qc for this should not missed something so fundamentally easy and it should never have been sent out.
