techguyone
I got my nice new pc delivered a few days ago.
I have the: INTERNAL 52 IN 1 CARD READER (XD, MS, CF, SD, etc) + 1 x USB 2.0 PORT thing, and initially it all worked fine.
Now, however only the USb 2.0 port works, none of the memory card slots are working. Initially this did work ok.
The front of the unit has 2 led's, normally (if the pc is off they both light up RED, however, once booted, one is red, and the other is a red/green mix. Previously it only showed that if a card was inserted.
I'm a little bit disappointed, as I ordered a motherboard with a load of USB ports. (ASUS® MAXIMUS VI GENE: RoG, PCI-e 3.0, SATA 3.0, USB3.0, THX)
Of the 4 usb 2.0 ports on the back (rest are usb 3.0) only 3 work, I wonder if the 4th was diverted to the card reader port?
Additionally the two front loaded usb 2.0 ports that come with the case (COOLERMASTER HAF 912 PLUS MID TOWER GAMING CASE) don't appear to be wired up, is this correct?
I already had to take the thing apart as one of the SATA connections had come loose during transit and wasn't showing up in windows.
Anyone have any advice (especially PCS)
I don't particularly want to RMA over a card reader.
