MisterCoggy
So i'm thinking about getting a Vortex III
Firstly, would people recommend the 15.6" or the 17.3"? For home and work use it will most likely be plugged into a monitor anyway, however there will be time when I could do with the portability for off-site work but i'd just like other peoples thoughts on what they prefer.
Laptop is for emails for work etc, gaming, and some light use of visual studio
Anyway, the spec i'm considering is:
i7 3610QM 2.30Ghz
8GB Kingston HyperX 1600mhz - Will probably buy another 8 if I feel the 8gb I have doesnt cut it...but i'm sure it will
Nvidia GTX680M - unless it's not worth the price hike from the GTX675? note: I play skyrim and I WANT max settings
2x Kingston hyperX 3k SSD 120GB in Rad0 - I've gone for this because TRIM is now supported so super super quick!
So yeah, any thoughts/feedback/opinions would be welcomed
i7 3610QM 2.30Ghz
