hi just powered up my computer ihave maelstrom t900 case the top and side fan are working ok but the rear is not seems to be connected ok any thought ?
i suggest that if you are confident in doing so, open up the case, (remove the power cable n all that) find the rear fan cable, and follow it, you should see a little 3 pin female plug at the end, which will hopefully be a near a 3 pin male connection on the mobo, just plug it in.
I think it will labeled as a fan header. or atleast fan something.
if you are not confident in doing so, give pcs a bell, but in the mean time you will be fine to use the pc.
