tracktor88
SPECS:
PRICE: 1.579,00 EUR
The laptop was ordered on 11/03/2019 and I received it on 15/03/2019.
Externally, the product arrived intact, the only flaw was that one of rubber foots had been thinner than the others: the laptop wobbled, but I solved unmount and repasting the piece adding some thickness.
Another negative thing: some screws was not properly tightened, but obviously it was only an operator's distraction.
External features:
Internal features:
For extreme-effort conditions I mean (after undervolt):
- Metro Exodus Epic Settings (No RTX) - min75? max85?;
- Ark Survival Evolved Epic Settings - min65? max75?;
I tested higher values of undervolt, but I noticed freezing, so I concluded that -0.120v is the maximum bound settable on my machine, without problems.
It must be said that the six-core-twelve-threads-based processor generally doesn't be 100% exploited from games software, which doesn't entirely optimize concurrency and parallelism, so it is normal in gaming to notice these temperatures.
In other contexts the laptop is very efficient, it doesn't show any sign of effort or high temperatures. An example is the combination of these applications open simoultaneosly:
During normal utilization, fans turn on only with low speed in some case, but generaly they are silently.
General considerations:
The value for money is great, it is impossible to find the components of this RECOIL at a price of around 1500eur by looking in the catalogs of other famous manufacturers. With RECOIL II RTX I didn't have to compromise components with total price.
Chassis & Display | Recoil Series: widescreen LED 72% NTSC opaco, full HD IPS 15,6" e 144 Hz (1920 x 1080) |
Processor (CPU) | Processor Intel Core i7 8750H 6 core (2,2 GHz, 4,1 GHz Turbo) |
Memory (RAM) | DDR4 SODIMM Corsair 2666 MHz 16 GB (2 da 8 GB) |
Graphics Card | NVIDIA GeForce RTX 2060 RAM video 6,0 GB GDDR6 DirectX 12.1 |
1[SUP]st[/SUP] Storage Drive | DISCO RIGIDO SEAGATE 1 TB 7 mm SERIAL ATA III 2,5" CON CACHE 128 MB (7.200 giri/minuto) |
1[SUP]st[/SUP] M.2 SSD Drive | SSD PCIe INTEL 760p M.2 NVMe 256 GB (fino a 3210 MB/sR | 1315 MB/sW) |
Memory Card Reader | Lettore schede 3 in 1 integrato (SD/SDHC/SDXC) |
AC Adaptor | 1 x Adattatore 180W AC |
Battery | Batteria Li-Ion Recoil II Series 46 WH |
Power Cable | 1 cavo di alimentazione europeo a trifoglio 1 metro |
Thermal Paste | PASTA TERMICA COOLER MASTER MASTERGEL MAKER |
Sound Card | 2 canali alta def. Audio + SoundBlaster Cinema |
Bluetooth & Wireless | LAN GIGABIT e WIRELESS INTEL AC-9260 M.2 (1.73 Gbps, 802.11AC) + BT 5.0 |
USB/Thunderbolt Options | 1 PORTA USB 3.1 (tipo C) + 2 PORTE USB 3.0 + 1 PORTA USB 2.0 |
Keyboard Language | TASTIERA MECCANICA ITALIANA CON ILLUMINAZIONE RGB INDIVIDUALE DEI TASTI |
Operating System | NESSUN SISTEMA OPERATIVO RICHIESTO |
Operating System Language | Italia/Italia Lingua italiana |
Windows Recovery Media | NESSUN RIPRISTINO RICHIESTO |
Office Software | Prova GRATUITA 30 giorni di Microsoft? Office? 365 (richiesto sistema operativo) |
Anti-Virus | NESSUN SOFTWARE ANTIVIRUS |
Browser | Microsoft Edge (solo con Windows 10) |
Notebook Mouse | MOUSE TOUCHPAD 2 PULSANTI INTEGRATO |
Webcam | WEBCAM HD 1 MP INTEGRATA |
Warranty | Garanzia Silver di 3 anni (1 anno Ritiro e reso, 2 anni Ricambi, 3 anni Manodopera) |
Delivery | 3 - 4 GIORNI PER LA SPEDIZIONE IN ITALIA |
Build Time | Costruzione standard da 4 a 6 giorni lavorativi |
Processed Date | 11-03-2019 |
Pre-Production Date | 11-03-2019 |
Build Date | 12-03-2019 |
Test Date | 12-03-2019 |
Awaiting Dispatch Date | 13-03-2019 |
PRICE: 1.579,00 EUR
External features:
- Display: visually fantastic, with great colours and very high luminosity.
- Keyboard: despite all negative comments that I read, I found the pseudo-mechanical keyboard very comfortable and relatively silent compared to a truly mechanical one.
- Chassis: it keep some fingerprints, but is solid and strong.
- Cooling: really well studied for a laptop of these dimensions.
Internal features:
- Processor: obviously the i7 8750H is, computationally speaking, one of the best high-level processors on the laptop market.
- macOs Mojave virtualized with 6GB of ram open in window (virtualbox), with Xcode open;
- Opera browser downloading system updates;
- Installation of Android Studio.
In this case I noticed a maximum of 60% usage of the CPU (balanced mode). I didn't any other checks during heavy-utilization session, so this is the only example.
- Video card: until now, I noted a maximum of 70 Celsius degree during the previous explained gaming sessions.
- Chassis temperatures: during gaming session the upper bar (in wich there are the turbo fan and the on/off buttons) reach rapidly high temperatures. The lower part, on the right of the touchpad (in which I think there are the 7200rpm HDD) becomes warm. These temperatures are obviously a compromise to be accepted for the price, the very thin dimensions and even the 2.1kg weight of this gaming laptop (withouth however needing a Nvidia MAX-Q graphic depotentiation).
- Cooling system: during the previous explained gaming sessions, the fans quickly turned on, manteining a medium-hig speed. Obviously, with settings optimization, it is possible to obtain lower fans' speed and temperatures. Generally fans are louder, but as I said before, it is the price to pay for thin dimensions with high-level components.
