RECOIL IV Replacement Charger
Hi I have a RECOIL IV 15.6" and I'm looking to get a second power supply. PCSpecialist has the RECOIL III charger available for €92. Will this work for my RECOIL IV? Or does anyone know where I can find the RECOIL IV charger online? Its a Chicony A17-230P1A, I tried looking but couldn't find one that wasn't coming from a website like Aliexpress, and I don't want to risk buying from there. Thanks in advance for the help!
The Recoil 3 was an entirely different laptop.
If you call PCS they'll be able to sell you an official one for the Recoil IV.
If you bought it off PCS, then if you go to your main PCS account, to the spares section, you can order one there also.
In my spares section is where I seen the Recoil III charger, that’s why I was confused. I contacted them and apparently the same charger works for both. Thanks for the answer.
Alman
Did the recoil lll charger work fine? It's also not listed under my spares :/. I've been looking on here and other places and having a lot of trouble finding a replacement.
