Replacement battery for Vyper 15.6"
So the battery for my laptop was always pretty bad, only held a couple of hours of charge when new and only after a few months it reduced to something like 35minutes on a full battery just watching youtube.
The spare parts for this model I got confirmation is just the same battery so I'm not too keen on purchasing one, is there somewhere else I can buy a better quality battery that would work with this laptop?
I've attached a couple of photos of the details for the power input in case there's some really knowledgeable people out there.
I know it's an old laptop but tbh after repasting it and getting it a new NVME, it still does the job I need it for.
Hiya, is this a pcspecialist system? Could you post your full specs from the order page?
Chassis & Display
Vyper Series: 15.6" Matte Full HD 45% NTSC LED Widescreen (1920x1080)
Intel® Core™ i5 Quad Core Processor 8300H (2.3GHz, 4.0GHz Turbo)
8GB Corsair 2400MHz SODIMM DDR4 (1 x 8GB)
NVIDIA® GeForce® GTX 1050 Ti - 4.0GB GDDR5 Video RAM - DirectX® 12.1
256GB ADATA SX6000 PCIe M.2 2280 (1000 MB/R, 800 MB/W)
Integrated 2 in 1 Memory Card Reader (SD, MMC)
AC Adaptor
1 x 150W AC Adaptor
1 x 1.5 Metre Cloverleaf UK Power Cable
Battery
Vyper Series 46WH Lithium Ion Battery
GIGABIT LAN & WIRELESS INTEL® AC-9560 M.2 (1.73Gbps, 802.11AC) +BT 5.0
1 x USB 3.1 PORT (Type C) + 2 x USB 3.1 PORTS + 4 x USB 2.0 PORT
Keyboard Language
PER-KEY RGB BACKLIT UK MECHANICAL KEYBOARD
NO OPERATING SYSTEM REQUIRED
NO RECOVERY MEDIA REQUIRED
Keyboard & Mouse
Webcam
INTEGRATED 1MP HD WEBCAM
Chassis & Display
AC Adaptor
1 x 150W AC Adaptor
Battery
Keyboard Language
Keyboard & Mouse
Webcam
When you say the battery life was only a couple of hours to begin with, were you gaming on battery?
yup, even used the nvidia control panel to force apps to only use igpu all the time
Yeah, that's a shame. You'd done everything you could do.
Unfortunately these are TongFang chassis, and I think the one you've got was the first version they released (or an early model).
They were a little bit "beta" shall we say, they had amazing specs, but to achieve the better specs, they cut corners a little on the build quality.
Now, it's possible that you had a defective battery in the first instance, although I have a sneaking suspicion around 2 hours was all that chassis could manage, but hopefully someone else with this model may be able to confirm. I have a sneaking suspicion that @barlew had this model which he ended up returning for other reasons, but he may be able to verify if he was seeing the same battery life.
It's a tough one, because TongFang are still relatively new to the market and these were early models, not many aftermarket manufacturers made alternative battery packs as far as I'm aware but I could well be wrong.
If you look on the underside there should be a manufacturers label with a chassis model number, it will be something like GxxNP or something like that format IIRC.
If you post the chassis number, then we can do a search and see if we can find an extended battery anywhere.
I can't find anything for that model number, only the later GK series chassis.
If you don't have any luck finding an aftermarket, you can always ask PCS for a legitimate one if they have stocks remaining.
barlew
Sorry for the late response life is hectic right now.
@spyderyour half right, i had the 17inch version which if memory serves had a bigger battery. I don't think I got much more than 2 hours out of it though.
Thanks, sorry, I know you're manic at the moment, appreciate your input (y)
