Review my spec and comment please
SreNar
Hello,
Please can someone review and comment on this spec please. I am planning to buy this spec. You feedback will help me a lot.
Please note I have width restriction which is 196mm so went for basic case.
Case PCS 3601 CASE
Processor (CPU)AMD Ryzen 7 5700G Eight Core CPU with Radeon™ Graphics (3.8GHz-4.6GHz/20MB CACHE/AM4)
MotherboardASUS® TUF GAMING B550-PLUS (DDR4, USB 3.2, 6Gb/s) - ARGB Ready!
Memory (RAM)16GB PCS PRO DDR4 2666MHz (1 x 16GB)
Graphics Card12GB NVIDIA GEFORCE RTX 3060 - HDMI, DP, LHR
1st M.2 SSD Drive1TB SAMSUNG 970 EVO PLUS M.2, PCIe NVMe (up to 3500MB/R, 3300MB/W)
DVD/BLU-RAY DriveNOT REQUIRED
Memory Card ReaderUSB 3.0 EXTERNAL SD/MICRO SD CARD READER
Power SupplyCORSAIR 550W CV SERIES™ CV-550 POWER SUPPLY
Power Cable1 x 1.5 Metre UK Power Cable (Kettle Lead)
Processor CoolingPCS FrostFlow 100 V3 Series High Performance CPU Cooler (AMD)
Extra Case Fans2x 120mm Black Case Fan
Wireless Router/HomePlugsHomePlug 500 Mbps Starter Kit - Internet Through Powerline
USB/Thunderbolt Options2 PORT (1 x TYPE A, 1 x TYPE C) USB 3.1 PCI-E CARD + STANDARD USB PORTS
Operating SystemWindows 11 Professional 64 Bit - inc. Single Licence
Alltruism
What will you be using the PC for?
And what monitor(s) (resolution / refresh rate) will you be using with it?
Regardless of use case, I would definitely recommend faster RAM with a Ryzen, at least 3200MHz.
The 5700G has integrated graphics, which you probably don't need if you're getting a separate GPU like the 3060.
I'm not sure that case would have much airflow even with the extra case fans, but if you need one less than 196mm wide there might not be many options.
sck451
I'm not sure there are any good cases narrower than 200mm. Sadly the 3601 is definitely not a good case because it offers pretty much no airflow at all.. The nearest I can find is the Phanteks P300A Mesh, which is 200mm; if that was possible then you could do the "send in my own case option":
If you were going for an iGPU based office PC, the 3601 might be OK. But for a gaming PC with a modern graphics card, it's just not enough in my view.
