RGB Help Please
AndyBell_
Intel® Core™ i7 Eight Core Processor i7-9700 (3.0GHz) 12MB Cache
Gigabyte Z390 UD: ATX, LG1151, USB 3.1, SATA 6GBs - RGB Ready
16GB Corsair VENGEANCE DDR4 2666MHz (2 x 8GB)
6GB NVIDIA GEFORCE RTX 2060 - HDMI, DP - VR Ready!
1TB INTEL® 760p M.2 NVMe PCIe SSD (upto 3230MB/sR | 1625MB/sW)
DVD/BLU-RAY Drive
PCS FrostFlow 120 Series RGB High Performance Liquid Cooler
LED Lighting
50cm RGB LED Strip
So in my PC i have a Gigabyte Z390 UD: ATX, LG1151, USB 3.1, SATA 6GBs - RGB Ready Motherboard, and an 50cm RGB LED Strip and ive tried to use Gigabyte's RGB Fusion 2.0, which doesn't seem to identify my motherboard unless i'm doing it wrong which is very possible. I'm not really sure how i can control them, also the RGB LED strip is something i couldn't find how to control anywhere
I'm not sure how PCS install the RGB strips and whether they are connected directly to a RGB header on the motherboard itself.
If it's on the motherboard itself I believe it's the Ambient LED app that you need for the Z390 UD but I cannot confirm. If this doesn't work for you I would call PCS and see if they can take you through the steps required :)
