Can anyone see an easy option to cancel an order rather then sit on hold for 3 hours again ?
Checked there doesn't show me the rma section so I've emailed them aswell as sat on hold... let's see which gets a reply quicker
Thanks but it just takes you back to the same cancellation page with a number to call
Yeah read that but can't find the rma form
75th here, same set up. thanks for the good news! (although there is the matter of the 850 power supply.)70th here too, 5900X and standard 3080, was told I could expect it in upcoming week or two
Wrong thread. This is only for the non-strix 3080Has anyone with a 3090/5950x had anything recently?
I envy your optimismI'm 13 days in Pre-Prod with at least another 60 day wait unless the stock fairy wants to bless us with GPU's soon. I might cry now.
I emailed for a refund and was refunded within 48 hours that was in octoberYeah read that but can't find the rma form
I have the 1000W RMx. And while I was told that, I was also told that it's just an estimation, it's all down to the supply arrivals in the end75th here, same set up. thanks for the good news! (although there is the matter of the 850 power supply.)
Once all components are in stock I doubt it would be too long. It doesn’t take that long to build a custom water loop, but obviously requires more testing. No-one except from PCS can give you an answer but you’re probably looking at a similar time to the rest of us at 70+ daysI sent an email last Monday asking for an update on Liquid Series and the 3080, I'm still waiting for a reply
I was originally quoted 42 days build when I ordered - I understand it takes time, there's a lot of bespoke work goes on in there fitting coolant lines etc. My question was once the 3080 comes into stock and I'm allocated "mine" am I then looking at a further 42 days to build, or is it more likely to be the 15-18 I can see quoted for a new order with a 3090 in ?
I'm only a young-un when it comes to the wait-list at 37 working days, but would quite like an update on even roughly "Yes, even if your stuff comes in NOW you have another 42 days to wait sonny!"
