jamiephillips909
7 more days and hit the big 100
I'm guessing this is the 3080 and 3090 GPUs and not Amd processors. Longer wait times for 3080 about 80-100 days (working days not including weekends) it is shorter for the 3090 but not exactly sure on the number of days I'd guess around 50 but depends on other components aswell.so is their a long wait for a pc with a 3800 in it >>or 3900??
3090 stock isn’t even (that) bad, doubt it would be over 30 days, unless you add the holy trinity of a 5900X and a 500D SE (bound to go out of stock)I'm guessing this is the 3080 and 3090 GPUs and not Amd processors. Longer wait times for 3080 about 80-100 days (working days not including weekends) it is shorter for the 3090 but not exactly sure on the number of days I'd guess around 50 but depends on other components aswell.
No amount of money will speed it up, it's just the way of the world right now, everyone has to wait.yea im down to spend a extra 1000 if i dont have to waith 3 months plus to get my pc![]()
i ment if the rtx 3900 build it easer to get than the rtx 3800No amount of money will speed it up, it's just the way of the world right now, everyone has to wait.
Please read the stickies in the forum as it contains all the information you're asking for.
Unless you’re 4k 144hz monitor. I’d say go down to the 3070. The 3090 isn’t even for gaming. The 6800XT isn’t far off the 3080 in performance either and almost certainly a shorter wait. I couldn’t advise against the 3090 any more (unless work requirements and 4k @144hz)i ment if the rtx 3900 build it easer to get than the rtx 3800
Guessing you mean the 3090 vs the 3080. And yes, 3090 stocks are not bad at all. It's the 3080 which has a 3 month+ wait at the moment.i ment if the rtx 3900 build it easer to get than the rtx 3800
yes it is , mine was ready in 30 days i amended from 3080 to 3090 on the 14th day and it went into building week and a half later.But im with an Intel processor though.i ment if the rtx 3900 build it easer to get than the rtx 3800
I'm curious if it was completed today and despatched say tomorrow would you be delighted or disappointed that you didn't make it too 100?
I think you’ve got to hit that hundred, I missed out on the cake and I need to see how special this 100 cake would of beenOh very good point, I'd be missing out on that cake from @AgentCooper #conundrum
Happy days96 days
edit: Less than an hour later its just gone into building.
