Ryzen 9 5950x for 4k video editing at high speed
Mfred68
I'm looking to build a pc with a Ryzen 9 5950x processor, the aim is to render 4k video as fast as possible for the price based on the cpu , so what motherboard, graphics card, ssd and ddr4 should I match the cpu with for optimum performance, as I want to avoid bottle necks in my system.
Are you looking for a pcspecialist build? It comes fully built.
If so, what's your max budget and what software packages are you using?
Mfred68
£2k maximum and cyberlink power director, as this is easiest software ive used for editing
if the 5950 is overkill, then please suggest a lower spec, but basically i want a super fast rendering process as i get very impatient waiting for a slow computer to do the task and this in turn puts me off the hobby of video editing.
Are you looking for a PC specialist build or to build your own?
