Samsung odyssey g9 Question
ThomasHewson
Hi there,
I know this is probably a no but i was wondering if i will be able to use this monitor on my current system while my beast is still in pre production. I know i won't be able to get the ultra awesome setting but was wondering if i can run it at basic settings? current specs below
COOLERMASTER CM STORM TROOPER - GAMING ENTHUSIAST CASE
Overclocked CPU
Overclocked Intel® Core™ i7-6700k Quad Core (4.00GHz @ up to 4.60GHz)
Gigabyte Z170X Gaming 3 ATX, LG1151, USB 3.1, SATA 6GBs
16GB HyperX SAVAGE DDR4 3000MHz (2 x 8GB Kit)
8GB NVIDIA GEFORCE GTX 1070 - DVI, HDMI, DP - GeForce GTX VR Ready!
512GB SAMSUNG PM961 M.2, PCIe NVMe (up to 2800MB/R, 1600MB/W)
DVD/BLU-RAY Drive
Regards
steaky360
Sure, I had the monitor running on a 1080 and was performing very well with descent settings so with some small amount of tweaking you'll be able to drive the monitor. I'm not sure if you'll be able drive the monitor at 240 Hz at its full resolution (I didn't try) but it worked fine at 120Hz for me.
Just expect to adjust settings to suit :)
