sidepartings26
Hi
I am ordering a Vortex 3 laptop. My main drive will be an Intel SSD 240GB. This is an audio laptop and will often be used near(ish) microphones so it does need to be fairly quiet.
My plan is to use the SSD as an OS drive and for current 'working on' projects and an additional HDD 'data' drive for archiving projects, software setups, pictures - non essentials; a setup I currently use and like (even with a 128GB SSD).
However, the second drive will hold large audio sample libraries which will be loaded into active projects at times and so the noise of that drive will be a factor.
I was going to go with the Seagate Momentus Xt 750GB because it's the only 6GB/S drive listed. However PC Specialist phone support said a few people have found it noisy. Online opinions are non-conclusive e.g. the only decibel stats I've found show it to be not bad http://techreport.com/review/22057/seagate-momentus-xt-750gb-hybrid-hard-drive/10.
The thing is, I don't really need the hybrid drive SSD element e.g. for booting because I will have an SSD anyway. So then I just thought get the WD Scorpio blue which is quiet 5400RPM bigger 1TB and better for battery.
The other option is to get a 480GB SSD and use backup drives connected by eSATA for various 'now and again' files given I mostly use Spotify anyway.
Any opinions? I am self employed and will be using the laptop to earn my living so cost can be stretched..
Anyone have experience of any of the mentioned drives and able to comment on noise level?
Best Wishes
Jonny
Best Wishes
Jonny
