Slimline laptop charger/adapter for a Clevo P775TM1-G?
Midwinter
Happy Thursday, PCSpecialistland. I have a Clevo P775TM1-G (2018's Octane, I think?). It's got a 19.5V and 16.9A input. The charger for it is wide and chunky. I'd like to get a thinner charger/adapter (it can be longer/wider, as long as it's less deep). I've had a look on Amazon and found slimline adapters, but they all have tiny ampere ratings. The closest I've found is this: https://www.amazon.co.uk/dp/B00AK75R6U/ref=psdc_430484031_t1_B00JE51E0M but at 4cm deep it's the same depth as the one PCSpecialist shipped me.
Am I running into the limitations of what is required to create a 16.9A adapter? Does anyone know where I could find a less deep one?
I think that's the problem. More power (amps) requires bigger components. If you do find a smaller one it may well run hot, especially when charging an empty battery and running the laptop at the same time.
Sent using Tapatalk
