Small Form Factor
Warbelian
Hello,
With my laptop recently "giving up", I'm on to a new adventure,
- Topic reference: https://www.pcspecialist.co.uk/forums/threads/nova-year-new-build.67960/page-4#post-652172
I really love small form factor things, I have this thing of moving out a lot so the least I have, the better it is for me, this also goes for computers,
Throughout the years I've always bought gaming laptops from PC Specialists because of the movebility but now I'm deciding to upgrade to a PC instead of a laptop.
The reason being, before I messed up my laptop I was playing a lot of:
New World - High Settings 1440p
Forza Horizon 5 - Ultra Settings 1440p
Cyberpunk 2077 - Ultra Settings 1440p
And my laptop was constantly on the 90's to 95c
I currently game with a 1440p monitor which I'm planning to make it double screen.
So yeah, I would like to keep the consistency on small things but got no clue about computer hardware.
My budget currently is £1500 but willing to extend a bit more if I can keep it for a good 3 to 4 years ahead of AAA games on ultra.
I've tried looking for this case but couldn't find it at PC Specialists,
IQUNIX ZX-1 Aluminum Mini-ITX Case​
As I fell in love when I saw this build, it totally projects my type of person, so anything like it, or that maybe could be transferred to it ? Would be appreciated.
But yeah, enough with the bio, here's the list to start building:
- https://www.pcspecialist.co.uk/computers/amd-sff-gaming/
Looking forward to see what you guys can achieve :D
Thank you
JUNI0R
Hello,
IQUNIX ZX-1 ALUMINUM MINI-ITX CASE​
Thank you
Heya! SFF is a tricky one and an even trickier one from SI's. It has a number of drawbacks; limited airflow, cramped cooling, difficulty upgrading, more expensive parts and the list goes on. That's why if you're able to make the stretch, I'd recommend going for a smaller ATX tower like the Corsair 220T, slightly larger case but way less drawbacks. Obviously it's your money at the end of the day and if your heart is set on SFF then that's fine, it's just something I wouldn't personally recommend.
As that case isn't on the PCS website, it might be worth contacting them and asking if you can buy one to send in- it's a feature they offer with their 'normal' sized PC's so they might be able to acommodate for an SFF with some gentle encouragement, otherwise the only other option involving PCS would be to buy the build you're after from them in a different case then transfer it over which would then void your warranty sadly.
Oh, I'd also recommend a watch of this video about gaming in ultra
JUNI0R
It didn't let me post in one post for some reason- Looking at an SFF build, this would probably be my recommendation for your budget and needs:
THERMALTAKE CORE V1 GAMING CASE
AMD Ryzen 5 5600X Six Core CPU (3.7GHz-4.6GHz/35MB CACHE/AM4) Solid gaming CPU
ASUS® ROG STRIX X570-I GAMING (DDR4, USB 3.2, Wi-Fi) - ARGB Ready! B450 is a dead platform for new builds so this expensive X570 is the only real option
16GB Corsair VENGEANCE DDR4 3200MHz (2 x 8GB) 16GB of RAM is the standard for a gaming PC these days, and AMD loves fast RAM
8GB NVIDIA GEFORCE RTX 3060 Ti - HDMI, DP, LHR Decent 1440p 144hz gaming GPU
1TB SEAGATE BARRACUDA SATA-III 3.5" HDD, 6GB/s, 7200RPM, 64MB CACHE More storage, mainly for bulk file storage
1TB INTEL® 670p M.2 NVMe PCIe SSD (up to 3500MB/sR | 2500MB/sW) Due to limitations, I've gone for a larger boot SSD for game storage, you could also swap the HDD for a 2.5 inch SSD
CORSAIR 750W TXm SERIES™ SEMI-MODULAR 80 PLUS® GOLD, ULTRA QUIET Best PSU you can get in that case, should just about allow for an upgrade
STANDARD AMD CPU COOLER Will be fine for the 5600X
GIGABIT LAN PORT + Wi-Fi (Wi-Fi excluded on A320I-K)
Windows 10 Home 64 Bit - inc. Single Licence [KUK-00001] I'd stick to Windows 10 for now
NO ANTI-VIRUS SOFTWARE WIndows Defender is fine
Price: £1,550.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-sff-gaming/vTwNU8ftqm/
Warbelian
Hey Junior,
Many thanks for the open discussion on that, I wasn't aware of the Ultra settings issue to be honest,
Taking consideration on what you said about upgrades being more expensive in the long run, I may have had a change of heart.
Would the below, based on 1 of your builds that I saw on the Mini PC section do the trick ?
512GB INTEL® 670p M.2 NVMe PCIe SSD (up to 3000MB/sR | 1600MB/sW)
1TB PCS PCIe M.2 SSD (2200 MB/R, 1500 MB/W)
NO OPERATING SYSTEM REQUIRED
NO RECOVERY MEDIA REQUIRED
Price: £1,512.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/6QCQ8rvhU5/
JUNI0R
Hey Junior,
It's less the upgrade price that's expensive, it's more the buy in price. ITX boards are more of a speciality and having that many features (especially in the case of the X570 STRIX) the boards generally cost more than their standard ATX counterparts, although that's one of a number of issues I'd avoid it for.
Spec above looks good! As we've got more motherboard choice, you could swap to the B550 TUF which would handle the 5600X perfectly adequately- that'd save about £100 which you could either put in your back pocket, or spend on this system? It's up to you. If you're going standard ATX it might be worth making use of it and going for a larger RMx850W PSU which will better improve upgradability down the road.
FerrariVie
Not sure if the default AMD cooler is going to do any better than the 90° that your laptop was having. The 5600x runs quite hot and I can say that by personal experience, as my brother has one with the stock cooler. He needed to underclock and undervolt the CPU in order to get lower temperatures that were around 85-90 and he didn't want to spend money on coolers
The 5600x is a very cool running CPU mate the stock cooler works just fine, if your brother is having problems with temperatures I'd say he has another issue probably with the cooler itself and certainly shouldn't have to undervolt/underclock
Warbelian
Going with this after the prices for the RTX chill a bit, got my laptop with a 2070 currently with pcs, if I've waited till now, I can hold a bit longer.
8GB NVIDIA GEFORCE RTX 3070 Ti - HDMI, DP, LHR
500GB SEAGATE FIRECUDA 530 GEN 4 PCIe NVMe (up to 7000MB/R, 3000MB/W)
Firefox™
Standard Build - Approximately 13 to 16 working days
Price: £2,170.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/Z64Z7WPrBq/
if you're going to wait for GPU prices to fall I think you'll be in for a very long wait, like rices of most stuff, the only way GPU prices are going to go is up
Warbelian
I pressed buy on this one, thoughts ?
Corsair H150i ELITE CAPELLIX RGB Hydro Series High Performance CPU Cooler
Looks good
Warbelian
The previous one didn't go through, so had to down-grade a few aspects.
Case COOLERMASTER MASTERBOX TD500 MESH ARGB GAMING CASE
Processor (CPU)AMD Ryzen 5 5600X Six Core CPU (3.7GHz-4.6GHz/35MB CACHE/AM4)
MotherboardASUS® STRIX B550-F GAMING (DDR4, USB 3.2, 6Gb/s) - ARGB Ready!
Memory (RAM)32GB Corsair VENGEANCE RGB PRO DDR4 3200MHz (2 x 16GB)
Graphics Card8GB NVIDIA GEFORCE RTX 3070 Ti - HDMI, DP, LHR
1st Storage DriveNOT REQUIRED
1st M.2 SSD Drive500GB SEAGATE FIRECUDA 530 GEN 4 PCIe NVMe (up to 7000MB/R, 3000MB/W)
2nd M.2 SSD Drive1TB INTEL® 670p M.2 NVMe PCIe SSD (up to 3500MB/sR | 2500MB/sW)
DVD/BLU-RAY DriveNOT REQUIRED
Processor CoolingCorsair H115i ELITE CAPELLIX RGB Hydro Series High Performance CPU Cooler
Operating SystemNO OPERATING SYSTEM REQUIRED
Windows Recovery MediaNO RECOVERY MEDIA REQUIRED
BrowserGoogle Chrome™
Build TimeStandard Build - Approximately 13 to 15 working days
Cooler is a bit overkill right now, but next year I want to upgrade to a 5950x,
I was in doubt if this B550-X was the wifi version but couldn't find info, so just bought the extender card.
I've got an AOC CQ27Q2 so at least a 3070 TI I had to get my hands on to fully take advantage of the 1440p gaming experience,
Obviously Ultra Settings are for show, but it's always good to see that it can handle for pretty much 95% games I play.
I went with a bit extra ram because I want to play Skyrim this Christmas for the first time and try to finish GTA 5 story mode, both modded versions so there's recommendations for more ram.
I didn't really need the firecuda but 7gb's ? dude that's insane.
I have mixed feelings about the motherboard still, there's a lot of talk with it comes to upgrades but to be honest, I think I will just upgrade the CPU and maybe put a bit more RAM and then I'm sorted for at least half a decade.
The VR experience I have is pretty much on my Quest 2, so the need for something really powerful isn't needed anymore.
Even if I stream lets say, I got my last years Nova which I can use as a streamer laptop so I guess I'm settled.
Chassis & DisplayNova Series: 15.6" Matte Full HD 144Hz 72% NTSC LED Widescreen (1920x1080)
Processor (CPU)AMD Ryzen 5 3600 Six Core CPU (3.6GHz-4.2GHz/36MB CACHE/AM4)
Memory (RAM)16GB Corsair 2666MHz SODIMM DDR4 (2 x 8GB)
Graphics CardNVIDIA® GeForce® RTX 2070 - 8.0GB GDDR6 Video RAM - DirectX® 12.1
1st M.2 SSD Drive500GB SAMSUNG 970 EVO PLUS M.2, PCIe NVMe (up to 3500MB/R, 3200MB/W)
Memory Card ReaderIntegrated Micro-SD Memory Card Reader
AC Adaptor1 x 230W AC Adaptor
BatteryNova Series 4 Cell Lithium Ion Battery
Sound Card2 Channel High Def. Audio + SoundBlaster™ Cinema
Bluetooth & WirelessGIGABIT LAN & WIRELESS INTEL® Wi-Fi 6 AX200 (2.4 Gbps) + BT 5.0
What are your thoughts guys ?
Anything you'd change really ?
Have a great one :D
JUNI0R
CaseCOOLERMASTER MASTERBOX TD500 MESH ARGB GAMING CASE
Have a great one :D
Looks pretty good to me, all seems fair! I was gonna suggest the 4000X then realised the configurator wouldn't allow it with the 70TI 😕 😂
Warbelian
That was actually my first pick as well :ROFLMAO:
I was gutted when it didn't let me, but between the td500 and 5000x, I had to go for td500, specially because of space as well. As it is I already had to buy a pc desk mount to make it live under my desk.
Also the air-cooling from the td500 isn't that bad from the reviews I've seen, even pcs seems to ship that one out with most pre-builds.
JUNI0R
The configurator only accounts for front mounting and doesn't take into consideration the majority of cases can top mount these days- the 4000 series is especially good because you can have RGB RAM and a 240mm AIO top mounted and it's not super large (which isn't the case for the TD500). Oh well.
The TD500 is indeed a solid case. If Corsair didn't exist it'd probably be one of my favourites
Warbelian
That's a good point you know,
I will ask them if it's possible to do the swap of the mounting positions and get the Corsair instead,
Hopefully it's a doable project, thanks for bringing that up.
Warbelian
The team managed to do the swap, very happy with the change.
Got my laptop back as well, the motherboard had to be swapped, it was at no extra cost either which is amazing.
