SOLVED. New build won't turn on - fresh out of box
AFSutton
Opened it up tonight for first time and can't get it to power on at all, I've contacted support but just wanted to see if there was anything else anyone could recommend in the meantime. Specs below.
Looking at similar threads on the subject I've gone back into the machine and checked connections, all seem fine (PSU to Motherboard etc). The only concern I have is regarding the power button itself - I can't tell if it's the cable management snagging it - but it does appear to be a bit snug in there. I've tried to ensure it's properly in but I still can't get the machine to power on.
Intel® Core™ i5 Six Core Processor i5-12400F (Up to 4.4GHz) 18MB Cache
ASUS® PRIME B760M-A WIFI (mATX, LGA1700, DDR5, PCIe 4.0, Wi-Fi 6)
32GB Corsair VENGEANCE DDR5 4800MHz (2 x 16GB)
8GB NVIDIA GEFORCE RTX 4060 - HDMI, DP, LHR
512GB PCS PCIe M.2 SSD (3500 MB/R, 3100 MB/W)
960GB KINGSTON A400 2.5" SSD, SATA 6 Gb (500MB/R, 450MB/W)
DVD/BLU-RAY Drive
NOT REQUIRED
CORSAIR 550W CX SERIES™ CX-550 POWER SUPPLY
PCS FrostFlow 100 ARGB V3 Series High Performance CPU Cooler (INTEL)
ONBOARD LAN PORT
NOT REQUIRED
Many thanks!
paul1224
The cable to the right doesn't seem to be fully seated from that picture so if you can, re-seating it would be advisable. Also assume the power button at the back of the PC for the PSU is definitely on?
AFSutton
In a cruel twist I was doing a last look over it, the PSU connection wasn't clipped in fully.
So I completely missed it. I'll get the thread locked. But thanks for the reply. Up and running!
