Hello
I have spent a complete day researching on the internet for a solution to my query. Nothing found yet - not even near so I thought I would give you experts a go!
My PC has a built-in Realtek soundcard which crackles and pops so I thought I would buy a PCIe soundcard to match my Logitech Z5500 speaker system and Beyerdynamic DT770 Pro headphones.
I'm going round in circles with this one, for one reason or another. I have shortlisted it down to two (Creative Soundblaster ZxR and Asus Xonar Essence STX 11 7.1) and I found negatives on both of those so I started again, looking at external/USB sound cards.
I really fancied the Asus Xonar U7 Compact 7.1 which has got good reviews. Now, the problem is that I can't find out if it is compatible with my Logitech speakers. My connections are: front (green) rear (black) centre/subwoofer (orange) and the Asus has umpteen connections and I don't know which one to put where or if they will work together.
I don't have a TV but I do watch BluRay/HD movies through the PC which is mainly DTS or Dolby. I listen to FLAC music through my headphones. The bottom line is that I want to get the purest sound possible with what I've got (or intend to buy).
So how do I connect the Xonar U7 to the Logitech Z5500 or are there any other sound cards you would recommend.
I've been told that the Realtek DAC is useless and the Logitech DAC is no better - that's one of the reasons for me wanting the upgrade. Apparently the Logitech is better with analogue rather than optical.
Apologies for the long version ..... but I wanted to spell things out so you can get a fuller picture.
Thank you.
Thank you.
