Hello
Please can you help. I recieved this additional mesh panel with my new PC in the peripherals box.
Does anyone know what it is for please? Or is it simply spare?
Thanks
It won’t affect performance at all, just may increase sound. Just check there’s not a panel missing from the build, maybe it is a spare.Thank you
My cooler is - Noctua NH-U14S Ultra Quiet Performance CPU Cooler
Should I try and fit it or if the guys at PCS have missed it out - assume they missed it out for a reason.
If it's only an additional sound damper I should be okay without it - as it shouldn't affect performance?
Thanks for your help
That looks like it's the optional top dust cover that comes with the case as the top sound dampening panel can be removed for added ventilation. Is the top of your case solid? If it is, then the sound dampening is in place.
If you check the overview page for the case and scroll down to the ventilation bit, they show how it looks with or without the SD panel:
Silencio case
