Spec / Case help
Fourteenth
Hello,
I'm wanting a full corsair build, but unfortunately none of the cases PCS sell seem to work with the below specs.
I've looked online and people seem to recommend the corsair iCUE 5000X case, which I've noticed PCS do not have listed (I'm assuming due to out of stock?)
If I was to pruchase this case would the below specs be compatible? I.e. in terms of the selected GPU and processor cooling? I'm also unsure if it would allow extra case fans, and if so how many maximum?
BE QUIET! DARK BASE PRO 900 REV. 2 FULL TOWER GAMING CASE
Overclocked CPU
Overclocked AMD Ryzen 9 5950X 16 Core (3.4GHz @ up to 4.55GHz)
64GB Corsair VENGEANCE RGB PRO DDR4 3200MHz (4 x 16GB)
24GB ASUS ROG STRIX GEFORCE RTX 3090 - HDMI, DP
Braided Power Supply Cables
CORSAIR Premium Individually Sleeved PSU Cable Kit Pro - Black - Is there any benefit in getting this?
CORSAIR iCUE H150i ELITE LCD Display RGB CPU Cooler
Extra Case Fans
2.5G ETHERNET PCI-EXPRESS CARD (10/100/1000M/2.5G) (1 x RJ45)
Also, side note - Can any one recommend any changes you would make to this build? The PC will be used primarily for gaming.
Thanks in advance,
Alex
MrWilson
Godlike
There are a few bits I would change to be honest. If you could please answer the following it'll help us spec us something to your needs.
What is your budget?
What are you using it for besides gaming? e.g Streaming, Editing, Rendering etc
What monitor are you pairing this with? Make and Model or Resolution and Refresh Rate is handy to know, so we can pair an appropriate GPU for gaming.
As above. It has to be said though, you haven't specced a gaming machine. That's a rendering/dev style rig. You could spend half of what you have budgeted and have next to no difference on the gaming front :)
Fourteenth
Hi guys,
Thanks for your replies. The PC will be primarily used for gaming but I will be using it for dev work aswell (nothing too intense just react/node dev work)
My budget is around £4500.
Currently I am using the gigabyte aorus F127Q quad hd 27inch IPS monitor, (refresh rate is 165hz via DP) but I'll more than likely upgrade and purchase a better monitor further down the line, so not wanting to base my build around this.
Thanks again
Gaming monster below. It'll easily cover your dev requirements as well.
Intel® Core™ i7 12-Core Processor i7-12700K (3.6GHz) 25MB Cache
ASUS® ROG STRIX Z690-A GAMING WIFI D4 (LGA1700, USB 3.2, PCIe 5.0) - ARGB Ready
Graphics Card Support Bracket
PCS GRAPHICS CARD SUPPORT BRACKET
2TB SEAGATE FIRECUDA 530 GEN 4 PCIe NVMe (up to 7300MB/R, 6900MB/W)
CORSAIR 1200W HX SERIES™ MODULAR 80 PLUS® PLATINUM, ULTRA QUIET
Microsoft® Edge
Price: £2,895.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/intel-z690-pc/B!wpD!Ngg7/
