Spec Check and Questions
pjb729
I am ordering a new PC, see the spec below, I am 70 and have never really used a SSD drive in my main PC other than for backup. As you can see I have selected a 2TB INTEL SSD as my first drive and intend to put a Seasgate HDD, which I already have, in as my second drive.
My questions are, for those people who understand these things
1. Is there anything I should be aware of about using a SSD as my 1st drive, the 1st drive will have my OS on it?
2. Can I mix Sata HDD and SSD drives, I assume I can, the 2nd Sata 1TB HDD drive will simply be for storage.
The PC is not for gaming, just for my research and general use, some of the files I send and receive can be very large which is why I have selected the configuration I have.
I did consider building my own PC using my exisisting case but decided if I wanted a SSD main drive it would be best left to PCSpecalists. I had already purchased Win 11 Pro OS I'm hoping that PCSpecalist will load Win 11 Pro onto the SSD when they test the configeration and then I can enter my Key into it when I receive the PC.
Any advice or pointers will be gratefully received, I remember when I had a 50mb Winchester HDD, 50mb of storage how would I ever use all of that :) time and technology certinly do move forward.
Case PCS P209 ARGB MID TOWER CASE
Processor (CPU)Intel® Core™ i5 Six Core Processor i5-11400 (2.6GHz) 12MB Cache
MotherboardASUS® PRIME B560-PLUS (DDR4, USB 3.2, 6Gb/s) - ARGB Ready!
Memory (RAM)16GB Corsair VENGEANCE DDR4 3000MHz (2 x 8GB)
Graphics CardINTEGRATED GRAPHICS ACCELERATOR (GPU)
1st M.2 SSD Drive2TB INTEL® 670p M.2 NVMe PCIe SSD (up to 3500MB/sR | 2700MB/sW)
DVD/BLU-RAY DriveNOT REQUIRED
Memory Card ReaderUSB 3.0 EXTERNAL SD/MICRO SD CARD READER
Power SupplyCORSAIR 450W CV SERIES™ CV-450 POWER SUPPLY
Power Cable1 x 1.5 Metre UK Power Cable (Kettle Lead)
Processor CoolingPCS FrostFlow 120 Series RGB High Performance Liquid Cooler
Extra Case Fans1x 120mm Black Case Fan (configured to extract from rear/roof)
Wireless Network CardWIRELESS 802.11N 300Mbps/2.4GHz PCI-E CARD
Operating SystemNO OPERATING SYSTEM REQUIRED
Hi there and welcome. There’s nothing you really need to know about SSDs as such. The only thing that springs to mind is that you shouldn’t use the defragment tool to tidy them up, that’s a big no no. A mixture of drives also isn’t an issue, systems are fully happy to have different types on board.
As for the OS, PCS will install a test version of Windows onto the system in order that they can check it’s working and run the various stress tests. You can input your own key onto that but we’d generally recommend a full clean installation of the OS so that you’ve got a clean slate to work from. The extra ten minutes spent doing that can save a lot of heartache when it comes to any troubleshooting.
Would you like any advice on the spec itself as there’s a few areas we could optimise? The 11th gen Intel chips are not something we recommend, they’re a very poor choice. If you let us what budget you’re working with I’m sure we can get the build improved 🙂👍
pjb729
Thank you for the reply.
I chose the Intel® Core™ i5 Six Core Processor i5-11400 as it has a built in GPU, is resonably priced and has good performance for the type of use I intend for the PC, I am open to susggestions for a spec up to £1,000 but remember I'm not a gamer :). Most of my big files are XL files containing DNA data.
Thank you for the tip about SSD and defragmentation, what stops the files on the SSD becoming fragmented???
The way SSDs work, it doesn’t really matter where the data is as there’s no moving parts. It doesn’t have to be laid out in a nice neat track like with a HDD. If you defragged an SSD, all you be doing is using up write cycles and shortening it’s lifespan.
I’ve knocked up an alternative spec for you to have a look at. It’s the AMD 5600G, which performs better than that Intel offering and is way more power efficient. I’ve also added in an extra, smaller M.2 drive. The logic is that if you just keep the OS and programs on that disc it keeps things running snappily and you wouldn’t lose your current projects/data if you need to reinstall Windows at any point. That’d allow the second M.2 SSD to hold your current data before archiving it onto the HDD. Other changes are the case, which is better for airflow and keeping those components cool, and the power supply, which is a better model, the fan only kicks in when it needs to and it’s a much quieter proposition than the CV range.
AMD Ryzen 5 5600G Six Core CPU with Radeon™ Graphics (3.9GHz-4.4GHz/19MB CACHE/AM4)
ASUS® PRIME B550-PLUS (DDR4, USB 3.2, 6Gb/s) - ARGB Ready!
500GB SEAGATE FIRECUDA 530 GEN 4 PCIe NVMe (up to 7000MB/R, 3000MB/W)
STANDARD AMD CPU COOLER
NO RECOVERY MEDIA REQUIRED
Firefox™
Price: £934.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/VPgfgrvQ8a/
pjb729
I like the idea of a seperate location for the OS and Progammes, reinstalling windows is a pain I could do with out
"The SSD doesn’t have to be laid out in a nice neat track like with a HDD" this makes sense (y)
I will have a look at the AMD Ryzen 5 5600G Six Core CPU
sck451
Firefox™
Yes to this build, but there's no point combining a 5600G with a PCIe 4.0 SSD: the 5600G only supports PCIe gen 3.
pjb729
Question
Is the
500GB SEAGATE FIRECUDA 530 GEN 4 PCIe NVMe (up to 7000MB/R, 3000MB/W) in the 1st M.2 SSD Drive Position
And the
2TB INTEL® 670p M.2 NVMe PCIe SSD (up to 3500MB/sR | 2700MB/sW) in the 1st Storage Drive Position
or doesn't it matter ?????
pjb729
I think the Amd Ryzen 5 5600G processor is a better option.
Below is the Revised spec just a couple of questions
1. Is the
And the
2. If the 5600G only supports PCIe gen 3 what is the best selection for the 1st M.2 SSD Drive Position ?
2nd M.2 SSD Drive
2TB INTEL® 670p M.2 NVMe PCIe SSD (up to 3500MB/sR | 2700MB/sW) (Special Offer)
You’d want the primary OS drive in the first M.2 slot. As @sck451 has rightly pointed out, the 5600G is limited to PCIe Gen 3 so wouldn’t be able to take advantage of the Firecuda’s amazing speed. So you could substitute said Firecuda with something like the 500GB Samsung 970 or the 512GB Intel 670. There’s not much between them but I have the Samsung and it’s been hella reliable, that’d be my own preference.
I would recommend going for a minimum of 3200MHz frequency on the RAM. Ryzen benefits hugely from having fast memory on board.
The WiFi card should really be bumped up to the AX200 for the extra few pounds it’ll cost. It’s much better than the default one, which I don’t think is even officially supported anymore.
pjb729
I have dropped the Wi Fi card, I can't remember why I put it in the first place.
I have selected the 500GB Samsung 970 Evo plus
I have selected the 3200MHz Ram
pjb729
This is the spec, please let me know if there are any errors or omissions as I intend to order this tomorrow
Thank you very much for all your help
CaseCORSAIR 4000D AIRFLOW TEMPERED GLASS GAMING CASE
Processor (CPU)AMD Ryzen 5 5600G Six Core CPU with Radeon™ Graphics (3.9GHz-4.4GHz/19MB CACHE/AM4)
MotherboardASUS® PRIME B550-PLUS (DDR4, USB 3.2, 6Gb/s) - ARGB Ready!
Memory (RAM)16GB Corsair VENGEANCE RGB PRO DDR4 3200MHz (2 x 8GB)
1st M.2 SSD Drive500GB SAMSUNG 970 EVO PLUS M.2, PCIe NVMe (up to 3500MB/R, 3200MB/W)
2nd M.2 SSD Drive2TB INTEL® 670p M.2 NVMe PCIe SSD (up to 3500MB/sR | 2700MB/sW)
Power SupplyCORSAIR 550W TXm SERIES™ SEMI-MODULAR 80 PLUS® GOLD, ULTRA QUIET
You’re welcome!
Looks good. I notice you picked the RGB RAM, was that intentional? It’s no different than the standard Vengeance other than having pretty lights.
pjb729
That wasn’t intentional I will alter it 😂
There’s an example of the benefit of having a second pair of eyes review the spec 👀
pjb729
Case CORSAIR 4000D AIRFLOW TEMPERED GLASS GAMING CASE
Memory (RAM)16GB Corsair VENGEANCE DDR4 3200MHz (2 x 8GB)
pjb729
Not having seen the RGB Memory before the question "Why would anyone want such a thing" did cross my mind when AgentCooper pointed it out!!!!! The question wasnt in my mind that long before I decided to dismiss it and file it in the "Odd" section
