Spec review
Good afternoon all,
Following my current PC (5yr old PCS system) suddenly dying, and no measures I take bringing her back to life, I have decided to bite the bullet and go for an upgrade.
Can I ask for people's thoughts on the following:
PCS LUMIN ARGB MID TOWER CASE (WHITE) (PWM)
Promotional Item
AMD Ryzen 9 9900X3D 12 Core CPU (4.4GHz-5.5GHz/128MB w/3D V-CACHE/AM5)
ASUS® ROG STRIX X870-F GAMING WIFI (AM5, DDR5, M.2 PCIe 5.0, Wi-Fi 7)
32GB Corsair DOMINATOR TITANIUM DDR5 7200MHz CL34 (2 x 16GB) KIT
32GB PALIT GEFORCE RTX 5090 GAMEROCK - HDMI, 3 x DP
2TB PCS PCIe M.2 SSD (3500 MB/R, 3100 MB/W)
CORSAIR 1000W RMx SERIES™ ATX 3.1, MODULAR, CYBENETICS GOLD
CORSAIR ICUE LINK TITAN 360 RX LCD RGB HIGH PERFORMANCE CPU COOLER
ID-COOLING FROST X45 THERMAL PASTE APPLICATION
Extra Case Fans
2 x 120mm Thermaltake TOUGHFAN 12 Case Fans
ONBOARD 2.5Gbe LAN PORT
NONE OR ONBOARD Wi-Fi (MOTHERBOARD DEPENDENT)
Microsoft® Edge
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/mdp7WP2RSZ/
Monitors are a 32" Samsung 4k 120hz (unable to get exact model right now) and a 27" Samsung C27F390FHU.
Main use: Gaming
Budget: £4-4.5k
Much appreciated!
Mat
Ekans2011
Good afternoon all,
What is your "dead PC's" full specs? Perhaps it can be fixed without wasting a platform that is still good and has plenty of life left.
Main use: Gaming
Budget: £4-4.5k
Here are two options for a top-tier 4K gaming PC: a full white one and a standard black one.
1) WHITE
N.B. There's a bug in the configuration regarding SSD Gen5 compatibility for the X870E AORUS PRO Motherboard.
The price will be little higher, around £3125.
CORSAIR FRAME 4000D RS ARGB MODULAR - WHITE
AMD Ryzen 7 9800X3D Eight Core CPU (Up to 5.2GHz/104MB w/3D V-CACHE/AM5)
GIGABYTE X870 AORUS ELITE WIFI7 ICE (AM5, DDR5, M.2 PCIe 5.0, Wi-Fi 7)
32GB Corsair DOMINATOR TITANIUM DDR5 6400MHz CL32 (2 x 16GB) KIT - WHITE
16GB MSI GEFORCE RTX 5080 VENTUS 3X OC WHITE - HDMI, 3 x DP
1TB CRUCIAL T705 GEN 5 M.2 NVMe PCIe SSD (up to 14,500MB/sR, 12,700MB/sW)
2TB CRUCIAL T500 GEN 4 M.2 NVMe PCIe SSD (up to 7400MB/sR, 7000MB/sW)
CORSAIR 1200W HXi SERIES™ ATX 3.1 & 5.1 PCIe MODULAR 80 PLUS® PLATINUM V2
CORSAIR ICUE LINK TITAN 360 RX RGB HIGH PERFORMANCE CPU COOLER - WHITE
NO OPERATING SYSTEM REQUIRED
NO RECOVERY MEDIA REQUIRED
Firefox™
Price: £3,068.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-white/VFf269Efwv/
2) BLACK
LIAN LI O11DYNAMIC EVO RGB GAMING CASE
GIGABYTE X870E AORUS ELITE WIFI7 (AM5, DDR5, M.2 PCIe 5.0, Wi-Fi 7)
32GB Corsair VENGEANCE RGB DDR5 6000MHz CL30 (2 x 16GB)
16GB PALIT GEFORCE RTX 5080 GAMINGPRO - HDMI, 3 x DP
Firefox™
Price: £2,995.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/nbeP30Dn2X/
Appreciate the quick response!
Current PC has the following specs:
NZXT H511 MID-TOWER GAMING CASE (BLACK)
Promotional Item
Get 1-Year Founders Membership to GeForce Now w/ select RTX Cards
512GB PCS PCIe M.2 SSD (2200 MB/R, 1500 MB/W)
ARCTIC MX-4 EXTREME THERMAL CONDUCTIVITY COMPOUND APPLICATION
Extra Case Fans
1 x 120mm Black Case Fan
Microsoft® Edge
Welcome Book
Logo Branding
PCSpecialist Logo
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/peSW7E0mTM/
Ekans2011
Promotional Item
Extra Case Fans
Microsoft® Edge
Welcome Book
Logo Branding
PCSpecialist Logo
The platform itself, with the exception of the absolutely inadequate power supply, was not so bad designed, however the storage configuration was not ideal. What kind of troubles are you experiencing?
Believe it or not but that spec was defined on these forums 5 years ago. The only thing I added to it was another 16gb of ram.
The pc has completely shut down, and no removal/disconnection of components helps to bring it back, yet the PSU is still working due to the RGB lights on the back of the mobo illuminating.
The white build you posted is certainly in the realm of where I would look for, and the drop down to 5080 makes sense, maybe I was being a bit to ambitious with what demand I thought I would throw at it.
He was advised a 750 watt PSU by @MrWilson
Ekans2011
Do you mean this? The recommended PSU for a 2060 was 750W.
That PSU didn't have enough power to sustain a 3060ti and a 5600X, especially since the ATX3 standard with built-in transient spikes protection had not yet been released at the time. I would not have gone below 850W for future GPU upgrades.
Personally, I'd try to fix and upgrade the existing build by replacing the PSU with something acceptable (1000W ATX3), removing the PCS drive and installing a couple of decent SSD NVME drives, and obviously upgrading the GPU for your monitor's 4K resolution (the Samsung C27F390FHU is unsuitable for gaming).
Ekans2011
Yes, 750W for a 2060 was acceptable, albeit with a bit too little room for upgrades; certainly, a 550W was not good for a 3060ti in the long run.
I have a donor PSU arriving next week to see if anything wakes up, though I am not hopeful.
The C27F monitor is not for gaming, rather running videos or things like discord on, so I am not too worried about that.
Appreciate everyone's inputs on this. I will make a decision on what route to go after testing the PSU in a week's time, though it is likely I will go for the 5080 build given the age of some of the components in the PC, and that quite a few of the hard drives are borderline antiquated 😂
