Stuck between cases for build any help?
Absolute XXIV
So i have the build itself pinned down but now there are 2 cases i can't decide between, the Lian Li Lancool 2 (Which i have heard is one of the best out there) or the Coolermaster MB530...
Anyone have any thoughts?
in terms of performance i went with Ryzen 3600x paired with the GTX 1660 Super and a 16GB RAM 3200 mhz
I would opt for the Corsair option myself 465x.... or even the iCue.
Out of the above it would be the Lian Li for me. The masterbox is just plain fugly in real life (IMO of course).
Absolute XXIV
What would you suggest for this specific spec
Processor (CPU)AMD Ryzen 5 3600X Six Core CPU (3.8GHz-4.4GHz/36MB CACHE/AM4)
MotherboardASUS® PRIME B450-PLUS (DDR4, USB 3.1, 6Gb/s) - RGB Ready!
Memory (RAM)16GB Corsair VENGEANCE DDR4 3200MHz (2 x 8GB)
Graphics Card6GB NVIDIA GEFORCE GTX 1660 SUPER - HDMI, DP - GeForce GTX VR Ready!
1st Storage Drive240GB ADATA SU630 2.5" SSD, SATA 6 Gb (520MB/R, 450MB/W)
2nd Storage Drive1TB SEAGATE BARRACUDA SATA-III 3.5" HDD, 6GB/s, 7200RPM, 64MB CACHE
DVD/BLU-RAY DriveNOT REQUIRED
Power SupplyCORSAIR 550W TXm SERIES™ SEMI-MODULAR 80 PLUS® GOLD, ULTRA QUIET
Processor CoolingSTANDARD AMD CPU COOLER
Wireless/Wired NetworkingWIRELESS INTEL® Wi-Fi 6 AX200 2,400Mbps/5GHz, 300Mbps/2.4GHz PCI-E CARD + BT 5.0
Operating SystemWindows 10 Home 64 Bit - inc. Single Licence
And also take into consideration the future what would you suggest i tweak from this and what Case would be perfect, Lian Li has my approval but i'd like to know from you
iCue is more than fine for any build. I don't recommend cases that wouldn't house the highest end of components happily. iCue is my lowest recommendation now, but it performs admirably for even the highest of loads..... after that, it's basically aesthetics and premium options.... hence why I like the 465X.
Lian Li is a high end cooling case, I'm just not that much of a fan of the aesthetics. It has you more than covered for quality and airflow though, no worries at all.
Build looks pretty good, are you aiming for 1080p gaming?
The only thing I would push on would be an M2 drive over the old standard SATA, and I would look for 500GB over 250 as it's filled so fast nowadays.
Absolute XXIV
Is the Ryzen 5 3600x with the RTX 2060 a good pairing for a monitor like
Acer Nitro VG271Pbmiipx 27 inch FHD Gaming Monitor - (IPS Panel, FreeSync, 144Hz (OC), 1ms, HDR 400, ZeroFrame, DP, HDMI, Black) (1080P)
OR
Acer ED273URPbidpx 27 inch WQHD Curved Monitor - (VA Panel, FreeSync, 144Hz, 4ms, ZeroFrame, DP, HDMI, DVI, Black) (1440P)
OR
You wouldn't buy the 2060, you'd buy the 2060 Super, but it's a 1440p GPU.
You really don't want 1080p, it's a really poor experience by todays standards, should be minimum of 1440p 144Hz
For 1080p you'd have the GTX1660 Super, but again, you don't want 1080p.
Absolute XXIV
Would i be able to get 1440p 144hz with just the RTX 2060? i have already stretched petty long considering i was initially going with 1660 Super, lets say i use the RTX 2060 for mostly 1080p but with the intention of going 1440p in the near future?
I want this build to last me a good 3 to 4 years before i even think about upgrading
No, you may be able to get 60fps at 1440p.
Absolute XXIV
So just just 1080p with one of those monitors on this build of Ryzen 5 3600x with the RTX 2060 and the 16GB RAM
Will be good,
Absolute XXIV
Okay, thanks man for the help Also what do you make of the 275R airflow case? i'm currently on the Spectrum which.....it as basic as it get & i'm concerned on the airflow
What’s the full build? There’s no point commenting on individual components as it’s of no bearing.
Absolute XXIV
CasePCS SR-628B RGB GAMING CASE
Change to: PCS SPECTRUM RGB MID TOWER CASE
Change to: 6GB NVIDIA GEFORCE RTX 2060 - HDMI, DP - VR Ready!
Change to: 1TB SEAGATE BARRACUDA SATA-III 3.5" HDD, 6GB/s, 7200RPM, 64MB CACHE
Change to: NONE
1st M.2 SSD DriveNONE
Change to: 512GB PCS PCIe M.2 SSD (2000 MB/R, 1100 MB/W)
Change to: PCS FrostFlow 100 RGB Series High Performance CPU Cooler (AMD)
LED LightingNONE
Change to: 50cm RGB LED Strip
Office SoftwareFREE 30 Day Trial of Microsoft® Office® 365 (Operating System Required)
BrowserGoogle Chrome™
MonitorNONE
Cable Management3 x PCS 1.5M Zip Cable Tidy - Professional Cable Management
Change to: PCS 1.5M Zip Cable Tidy - Professional Cable Management
Build TimeStandard Build - Approximately 12 to 14 working days
