Stuck in Boot loop after failed system Image restore. Can't get boot usb to work, help please!
TaskerC
So I was having trouble with a system build (software) and I set off a Macrium Reflect system image restore. When I came back to the laptop it was stuck in a permanent loop were it says Restarting on the windows light blue screen, then the screen goes blank for a couple of minutes and back to the same system restarting message and black again.
I got into the Insyde H2O BIOS looking to find a way to set the boot priority or system restore section but I am finding it to be very unintuitive.
I have the boot drive I got with my laptop plugged into the machine but I can't see a way to get the machine to boot from this drive.
I have attached a screen shot of the Boot From File explorer page but it is not obvious to me what to do next.
It looks like it is just showing me local files and not files from the usb boot drive.
Any help would be appreciated.
Thanks
Colin
Recoil 17" laptop
Windows 10
i7-11700K
RTX 3080
64Gb 2667Mhz
Insane.Pringle
Um.. is this a PCspecialist PC? if it isn't you would be better of going to another place like Tomshardware site or similar. they only help with PCspecialist computers here
if it is,my apologies and someone more knowledgable than me will be along at some point..
TaskerC
Yes it is a PC Specialist build.
Full spec:
Chassis & Display Recoil Series: 17.3" Matte QHD 165Hz 100% sRGB LED Widescreen
(2560x1440) + G-Sync
Processor (CPU) Intel® CoreTM i7 Eight Core Processor i7-11700K (3.6GHz) 16MB Cache
Memory (RAM) 64GB Corsair 2666MHz SODIMM DDR4 (2 x 32GB)
Graphics Card NVIDIA® GeForce® RTX 3080 - 16.0GB GDDR6 Video RAM - DirectX®
12.1
1st M.2 SSD Drive 2TB SAMSUNG 980 PRO M.2, PCIe NVMe (up to 7000MB/R, 5000MB/W)
Memory Card Reader Integrated 6 in 1 Card Reader (SD /Mini SD/ SDHC / SDXC / MMC /
RSMMC)
AC Adaptor 2 x 280W AC Adaptor
Power Cable 2 x 1 Metre UK Power Cable (Kettle Lead)
Battery Recoil Series Detachable 8 Cell Lithium Ion Battery (97WH)
Sound Card 2 Channel High Def. Audio + SoundBlasterTM Atlas & Super X-Fi
Bluetooth & Wireless GIGABIT LAN & WIRELESS INTEL® Wi-Fi 6 AX200 (2.4 Gbps) + BT 5.0
USB/Thunderbolt Options 2 x THUNDERBOLT 4 + 1 x USB 3.2 (TYPE C) + 3 x USB 3.2
Keyboard Language PER-KEY RGB BACKLIT UK KEYBOARD
Operating System Windows 10 Professional 64 Bit - inc. Single Licence
Operating System Language United Kingdom - English Language
Windows Recovery Media Windows 10 Multi-Language Recovery Image - Supplied on USB Drive
Office Software FREE 30 Day Trial of Microsoft 365® (Operating System Required)
TaskerC
Doh! I just looked at the most recent screen shots and I see that the USB drive did actually show up on the list when I went into the sub menu that time. It wasn't showing up before even though it had been connected.
Going to try and get the system back up now.
I will be back if I hit any problem.
Bastet
Try booting from the Macrium Recovery USB again & choosing to repair boot files.
Before you do anything, remove the M.2 drive and reseat it. We've had numerous issues caused by M.2 drives that needed reseating. Then run the Macrium Reflect restore again.
TaskerC
Thanks for the replies.
I did try all of the repair options I could see but nothing worked so I ended up rebuilding my software platform from the provided USB recovery key.
Interesting about the reseating issue, I had done all of the work before I saw that so will try it if I run into trouble again.
Cheers
