Supatek Duel monitor mount
Reckon this should do the job nicely, just got to lay my hands on a drill and a 10mm drill bit, then hopefully get it sorted tomorrow afternoon or on Sunday
Yeah i've not got space to go horizontal, left hand side of the M34WQ overhangs the side of the desk as it is, max load per mount is 10Kg, so fine there
Yeah, for your use, you definitely want a vertical setup anyway, would look far better.
