technical problem
callumby
monitor saying no input signal when connected to pc (yes i have checked all connections) and
also now when i go to turn pc off from power button it doesnt i have to flip the psu off.
this happened after my ps4 which usually sits on top fell of and hit the back panel of the pc
i did get a blue screen about a problem that said something about operating system kernel
any help appreciated
Is this a pcspecialist pc? Can you post your full specs from the order page?
Have you always been turning the PC off via the button rather than from the menu?
callumby
no its a custom but this is the only place i could find that might be able to help
normally gets turned off via menu but on the odd occasion the button done this for years and never had a fault
Sorry, these forums are for support on PCSpecialist systems only, you'd need an open forum like Toms Hardware
