Thinking of sending in my own case, Need confirmation
I just wanted to know if this case would be suitable for these components.
NZXT H710
Specs:
Send In Your Own Case
AMD Ryzen 9 3950X 16 Core CPU (3.5GHz-4.7GHz/73MB CACHE/AM4)
12GB NVIDIA GEFORCE RTX 3080 Ti - HDMI, DP, LHR
2TB SEAGATE FIRECUDA 530 GEN 4 PCIe NVMe (up to 7300MB/R, 6900MB/W)
CORSAIR iCUE H150i ELITE LCD Display RGB CPU Cooler
JUNI0R
NZXT H710
Specs:
Heya! Not especially I'm afraid. The NZXT cases have never been great for airflow (aside from the new H510 Flow) meaning temps are raised unnecessarily and therefore probably not a case I'd personally recommend. There's also some areas (Case, CPU, Storage) we could improve on this build. If you're able to give us some info, we'd be happy to optimise it for you!
1) Budget- What are you looking to spend
2) Uses- What will you be using the build for?
3) Monitor- What monitor will the build be paired with? Either make and model or resolution and refresh rate would be ideal!
4) the full spec, this includes Warranty and delivery decsions as well as the green configurable link
Once we have this info, we'd be happy to help with the build and assist with picking a more ideal case (y)
Heya!
thanks for the comment. I only really picked this case because I loved the look of it and nzxt cases in general. Most of the cases here im not a huge fan of. My budget is around £3600+ (just for the pc) and I use it for gaming and also some software like unreal engine 4/5, Maya, houdini, some adobe software too. Ill pretty much be working on this and gaming. The monitors will be 2
ASUS TUF Gaming VG27AQ HDR Gaming Monitor - 27 Inch WQHD (2560 x 1440), IPS, 155Hz*, ELMB Sync, G-SYNC Compatible, Adaptive-sync, 1 ms (MPRT), HDR10.
The full spec is here
Insurance
Simplesurance Purchase Protection inc. Accidental Damage & Theft
Standard Build - Approximately 9 to 12 working days
JUNI0R
Heya!
Insurance
Heya, sorry for the delayed response. UE, Maya and Houdini really aren't my areas of expertise so it's not something I'd feel overly confident in speccing up, I can have a go but I'd much rather open this one up to the floor.
Im looking for good cases that can fit all the parts listed below. I was considering the NZXT H710. It seems like a lot of the cases I like have bad airflow lmao.
Insurance
sck451
Hi there. This is quite a build, though there are various things that I'd question a little bit. What's the system for? If it's for gaming, what monitor do you have? And what's your budget?
Insurance
Can you include the configuration link at the bottom of the quote? There are several areas of the build, including the platform which aren't suitable. The 3950x is old generation and wouldn't be recommended.
sck451
Now, I'm a little unsure here. You don't need a 3080 Ti for a 1440p display like the VG27AQ. Maybe you need the 3080 Ti for your work purposes. If so, here's a build to match it. If you don't need the 3080 Ti for work purposes, the 3070/3070 Ti will be all the card you possibly need.
I'm going to suggest the Fractal Meshify S2 as a really good case in this kind of size. The H710 is all well and good, but it's not amazing. The S2 Meshify is amazing. I think it's gorgeous in white.
Intel® Core™ i9 16-Core Processor i9-12900K (3.2GHz) 30MB Cache Probably the best CPU there is right now
ASUS® ROG STRIX Z690-A GAMING WIFI D4 (LGA1700, USB 3.2, PCIe 5.0) - ARGB Ready A super motherboard to go with it
32GB Corsair VENGEANCE DDR4 3600MHz (2 x 16GB) A decent amount of RAM -- unless your work projects are really big, so maybe consider 64GB of 3200MHz?
12GB NVIDIA GEFORCE RTX 3080 Ti - HDMI, DP, LHR As discussed above
500GB SEAGATE FIRECUDA 530 GEN 4 PCIe NVMe (up to 7000MB/R, 3000MB/W) Super-fast boot drive
2TB INTEL® 670p M.2 NVMe PCIe SSD (up to 3500MB/sR | 2700MB/sW) For games and project storage
2TB SEAGATE BARRACUDA SATA-III 3.5" HDD, 6GB/s, 7200RPM, 256MB CACHE Oodles of storage space, with faster 7200RPM drives
CORSAIR 1000W RMx SERIES™ MODULAR 80 PLUS GOLD, ULTRA QUIET Giving plenty of headroom for the 3080 Ti and future upgrades
Corsair iCUE H115i ELITE CAPELLIX RGB Hydro Series High Performance CPU Cooler A strong cooler (the H150i is out of stock)
Microsoft® Edge
Price: £3,208.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/intel-z690-pc/wEJY3xwSgK/
Heya!
thanks for the comment. I use it for gaming and also some software like unreal engine 4/5, Maya, houdini, some adobe software too. Ill pretty much be working on this and gaming. The monitors will be 2
My budget is £3600+ just for the pc
