Thoughts + Advice on spec for office/poker use please?
azocarbo
CPU:
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor £155.99
Case:
------------what case please?---------
(I own a 3yr+ old case that fitted my old AW9D-MAX (Intel i975-ICH7) (Socket 775) m/b - I assume I need a new one?)
Motherboard:
-----------I can't find a motherboard that has 2 x 1920*1200 outputs and supports 1600mhz RAM. I have an existing graphics card mentioned below, but it's pretty poor. Help please?-----------
SSD:
Kingston 96GB V+100 2.5" SATA-II SSD - Read 230MB/s Write 180MB/s £82.99
RAM:
G-Skill 8GB (2x4GB) DDR3 1600Mhz RipjawsX Memory Kit CL9 (9-9-9-24) 1.5V £39.46
Rest of the system (already owned):
PSU
Coolermaster 460W eXtreme Power Plus PSU - 20+4pin 4+4 ATX12v 4x SATA 6pin PCI-E
Graphics
BenQ G2400W (1920x1200@60Hz)
256MB Radeon X1300/X1550 Series (Sapphire/PCPartner)
256MB Radeon X1300/X1550 Series Secondary (Sapphire/PCPartner)
CrossFire Disabled
Hard Drives
245GB Western Digital WDC WD2500YS-01SHB0 (SATA) 37 °C
977GB SAMSUNG SAMSUNG HD103SJ (SATA) 35 °C
Optical Drives
TOSHIBA DVD-ROM SD-M1712
Audio
Realtek High Definition Audio
azocarbo
Not sure what has happened here please? I went to edit it to put the name of the the SSD rather than the link and it was all gone.
Rakk
The Awesome
Until you've made how ever many posts (ie. I don't know the number), your posts get may moderated (if they have links it they definately do), this includes editing posts, so if it disappears, just be patient until a moderator can validate it.
azocarbo
It looks like getting 1600 RAM would require a P motherboard. Then that means relying on my shoddy graphics card.
http://www.ebuyer.com/262904-asus-p...cket-1155-8-channel-hd-audio-mini-itx-p8h61-i
I think this card has: HDMI/DVI/D-Sub, which is good for my dual monitors. It also has USB 3.0 so that's good.
It does say:
Memory
2 x DIMM, Max. 16 GB, DDR3 1333/1066 Non-ECC,Un-buffered Memory
Dual Channel memory architecture
Would that work with this cheap 1333 memory: http://www.amazon.co.uk/gp/product/B003N8GVUY/ref=nosim/?tag=hotukdeals-21
