Thoughts on this, with high end monitor
WOb
hi all,
thoughts please...
mainly using for work and gaming.
Any experience or areas i should consider changing ?
FRACTAL DEFINE 7 BLACK QUIET MID-TOWER CASE
Intel® Core™ i9 Ten-Core Processor i9-10900K (3.7GHz) 20MB Cache
ASUS® ROG STRIX Z490-F GAMING (LGA1200, USB 3.2, CrossFireX/SLI) - ARGB Ready
10GB ASUS ROG STRIX GEFORCE RTX 3080 - HDMI, DP (Xmas delivery not guaranteed)
2TB PCS 2.5" SSD, SATA 6 Gb (520MB/R, 470MB/W)
DVD/BLU-RAY Drive
CORSAIR 850W RM SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
Corsair H80i V2 Hydro Cooler w/ PCS Ultra Quiet Fans
Extra Case Fans
NO OPERATING SYSTEM REQUIRED
NO RECOVERY MEDIA REQUIRED
Monitor
ASUS XG279Q 27" G-Sync ROG Strix
Gavras
Master Poster
Is there a specific reason you want an Intel CPU ?
there are a number of reasons not to go Intel at moment.
An M.2 drive is a good investment in performance.
Cooling looks rather weak.
one of the forum experts will come along at some point.
as you have said what monitor is being used and type of use, the next thing will be what’s your budget.
increase the warranty to next level.
Ram is high unless you use that for work stuff, games do not need that much, MSFS is main hog and that’s 32gb.
  • Like
Reactions: WOb
There’s a few things I’d change... but can I ask what your budget is, types of games you’ll be playing, and what ‘work’ constitutes?
WOb
Work. HyperV and running a 8 or more vms each with 2 to 4gb ram. Hence memory and fast ssd.
gaming. Cod modern warfare, battle field. Hence 3080 and new monitor to take advantage of it
intel coz im usually down with intel. But i am reading good things about amd.
cooling - never gone water cooled, dont want high maintenenace cooling just fans. Not concerned with niose. Im deaf as a post
Ta for the info, helps me get a handle on things 👍
Sooooo, here’s the inevitable alternate AMD spec to have a look at. It’s a touch over budget but I reckon it’s worth it. Brand new design twelve core CPU, superior on both single and multi threading, thermal performance and far less security flaws than an Intel processor.
Kept the RAM high as per your remit on the work side of things. Tweaked the storage so you’ve got an ultra fast M.2 boot drive, and another one for your games and day to day stuff. I wouldn’t bother with an Ironwolf HDD but storage requirements are personal to the user so I’ve left that in there, I’m sure you chose it for a reason 👍
Put the H115i RGB cooler in there. These liquid coolers are maintenance free aside from a little dust removal once or twice a year. And they’re awesome, I’ve got the little brother of that one in mine and it’s been running pretty much constantly since purchase. They’re superior to fan cooling in every way now, gone are the days of horror stories about leaks ruining systems. In my opinion they’re getting to be a necessity on chips eight cores and upwards as they’re much more efficient than a fan and will keep a processor at optimum temperatures far better.
Now... the GPU. I’m currently using a 3070 with an ultrawide 1440p 144Hz monitor and it’s not even flinching when I chuck a system killer like Red Dead Redemption 2 at it. So I reckon it’s perfect for the screen you’ve picked out... unless you’re one of those nutters who demands that EVERY SINGLE POSSIBLE SETTING is set to ultra. If you are, then my plan unravels 😆
DVD/BLU-RAY Drive
Firefox™
Monitor
Price: £3,092.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/7m634Ea6sU/
  • Like
Reactions: WOb
Gavras
Master Poster
Where you say Fast SSD, compare the SSD you spec’d and a Samsung 980 Pro or 2 Tb firecuda M.2’s.
  • Like
Reactions: WOb
WOb
DVD/BLU-RAY Drive
Firefox™
Monitor
Thanks agent cooper. I will do some research on the amd above tomorrow and keep you posted
Gavras
Master Poster
Thanks gavras. Yeah sata ssd and m2 are poles apart. M2 almost double sata. Ill look into it buddy. Thanks
Yes definitely, unfortunately only one make of CPU currently does PCIe 4.0 at the moment.
it’s also the only one that is not getting replaced by a stop gap cpu early next year..
guess what the make is.
a clue.
it starts with A
  • Like
Reactions: WOb
WOb
a clue.
it starts with A
So intel got another chip out soon?
i keep hearing about amd and there resurgence. I need to read up on the ryzen.
whats wrong with intel chips ? Apart from security, thermals, always thought they had floating point edge and slightly better performance.
are amd really beating intel up these days like im reading about in the cpu product area?
WOb
Looks like i got a bit of reading to do. I will investigate and keep you in loop
thanks so much for the info and steer on other options
much appreciated
Yeah, Intel only really had the edge on single threading since the last generation of AMD CPUs, they’d been overtaken in every other area. But the 5000 series have now blown that away too.
  • Like
Reactions: WOb
WOb
Is the 5000 series the latest ?
whats supply like on the amd stuff ?
my current rig is screwed keeps blowing psu‘s however its 7 years old intel 3770k with ssd’s and 32gb mem. Nvidia1070ti
would really like summat before christmas.
Likely or wishful thinking ?
dont think me rude, i appreciate the info. But i got to hit the hay. I have work at 830am and im old, need my sleep. I will do some reading up and check back tomorrow.
once again thanks all for help
Gavras
Master Poster
Yep as @AgentCooper says the latest Zen 3 - 5000 CPU give Intel a good kicking.
the current CPU by Intel is due replaced early next year by Rocket Lake which is believed to be an interim gap until they sort out next architecture and drop in n.
Its a bit like AMD are taking the battle to Nvidia as well.
my last few systems have been intel and Nvidia cards for last 10 years, so not exactly an AMD fan boy lol.
If you look in to the Intel road map especially End Of Life side of things and board compatibility, it gets potentially Darwin to chose Intel.
WOb
Ryzen 7 zen 3 ? Im confused.
darwin. Does that mean madness.
drop in n ?
please explain or are these typos
WOb
Hi all.
back with my spec. Want to stay with intel for now, so please vet it for suitibility, rather than comparison to amd, which i know are probably better at present. But having more options isnt helping the decision process. I need to know if this is a good spec based on intels current flagship.
should i have any concerns with cooling given chosen solutions in this spec?
will be used for work. hosting 8 or more vm’s on hyperv. Hence the fast disk ssd and high memory.
will also be used for gaming, want best frame rates with settings at max where possible. Hence 3080.
all help and feedback appreciated.
regards,wob
spec below ... lol
DVD/BLU-RAY Drive
Monitor
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/intel-z490-pc/ar4ynCfBdy/
