I'm wondering if i ordered my setup with 1GB ATI Radeon 5450 PCI express - DirectX 11, would this card support dual monitors? i will be using two 19' samsung monitors.. any info will be gratefull
Thanks alot everyone... This is my final setup, but when i order this on friday will i need anything else like cables or adapters (for my two monitors )? any info will be gratefully appreciated!
PCS MAELSTROM T900 BLACK GAMING CASE (£59) Processor (CPU) Intel® Core™i3-550 Dual Core (3.20GHz, 4MB Cache) + HD Graphics Motherboard ASUS® P7H55-M SI: MICRO ATX VALUE MAINBOARD,USB 2.0 & SATA 3.0Gb/s Memory (RAM) 4GB SAMSUNG DDR3 DUAL-DDR3 1333MHz (2 X 2GB) Graphics Card 1GB ATI RADEON™ HD 5450 PCI EXPRESS - DirectX® 11 Memory - 1st Hard Disk 1TB WD CAVIAR GREEN WD10EARS, SATA 3 Gb/s, 64MB CACHE 1st DVD/BLU-RAY Drive 24x DUAL LAYER DVD WRITER ±R/±RW/RAM Memory Card Reader INTERNAL 52 IN 1 CARD READER (XD, MS, CF, SD, etc) + 1 x USB 2.0 PORT Power Supply & Case Cooling 450W Quiet 80 PLUS Dual Rail PSU + 120mm Case Fan (£29) Processor Cooling INTEL SOCKET LGA1156 STANDARD CPU COOLER Sound Card Sound Blaster® Audigy™ SE (£19) Network Facilities ONBOARD 10/100/1000 GIGABIT LAN PORT USB Options 6 x USB 2.0 PORTS @ BACK PANEL (MIN 2 FRONT PORTS) AS STANDARD Operating System Genuine Windows 7 Home Premium 64 Bit - inc DVD & Licence (£79) Monitor Samsung B1930N 19 inch Widescreen LCD Monitor (Already owned) 2nd Monitor Samsung B1930N 19 inch Widescreen LCD Monitor Speakers LOGITECH S220 2.1 SILVER/BLACK SPEAKER SYSTEM (£16)
You will be able to connect one directly into the VGA Port on the GPU, then there should also be an adapter sent with the PC to convert the DVI into a VGA port too. You shouldn't need to order any extra cables/adapters at all.
