The cables come from the support, they aren't separate. Unless im missing something, sorry I'm new to PC hardware, im more of a software person. :/And the male end to the GPU support obviously....
The male connector might just be there to allow you to daisy chain other ARGB devices to the bracket. For example, if you had the bracket and an ARGB LED strip, you could connect the strip to this male connector and then the female connector to the ARGB header on the motherboard.Can you take a pic of the cable connectors?
Ahh of course, the female only fits 3 pins but there are 4?The male connector might just be there to allow you to daisy chain other ARGB devices to the bracket. For example, if you had the bracket and an ARGB LED strip, you could connect the strip to this male connector and then the female connector to the ARGB header on the motherboard.
I'm confused, so where do I plug in a 3 pin?ARGB is 3 pin. 4 pin is 12V RGB.
There are 4 pins sticking out of the motherboard there, I can't plug in the 3 pin female into it.On your motherboard, bottom right corner, I circled it in green above. If that header is already used you’ll have to try and connect to the other ARGB header at the top. Check your motherboard manual, it shows layout of all headers, connectors etc.
Can't open it at the current time but I took a pic from the outside, it's the white bit, 4 prongs:Can you take a photo of motherboard?
I think you're right, when I'm able to open it up again, I will check and try daisy chaining it.View attachment 34439
Doing my best with the fish tank image, I reckon red is one of the fan headers, green is the 12V RGB, pink is the ARGB with something plugged into it, and yellow is the front panel/beep speaker.
Yep, plugged it in and my CPU fan (previously plugged in) still works fine, however the bracket doesn't do anything.View attachment 34439
CPU not but not bracket.Bracket plugged into header, and CPU cooler plugged into the daisy chain, correct?
If you change the ARGB in Armoury Crate, does it have any impact on CPU or bracket?
