Upgrading my old boy
Justyna
HI all!
I am currently toying with the idea of upgrading my desktop. Bought in 2020 still manages to run KCD2 on medium settings (the best of boys).
Thinking of upgrading the GPU, CPU, add RAM and storage. Im 5 years behind in the PC master race and would appreciate some help. Cheers!
My questions are:
-GPU: was looking at AMD Radeon RX 7800 XT? would that be a good pick? Seeing that it is a much chunkier graphics card, would I need to upgrade my power supply? Or cooler?
-CPU: Ryzen 7 7800X3D?
-RAM: can I just add another 2x8GB sticks to my motherboard?
-Storrage: can I add an SSD? what should I be looking at?
OLD BOY SPECS:
Case COOLERMASTER MASTERBOX K500 ARGB GAMING CASE
Processor (CPU) AMD Ryzen 5 5600X Six Core CPU (3.7GHz-4.6GHz/35MB CACHE/AM4)
Motherboard ASUS® STRIX B550-F GAMING (DDR4, USB 3.2, 6Gb/s) - ARGB Ready!
Memory (RAM) 16GB Corsair VENGEANCE DDR4 3200MHz (2 x 8GB)
Graphics Card 6GB AMD RADEONTM RX 5600 XT - HDMI, DP, DX® 12
1st Storage Drive 1TB SEAGATE BARRACUDA SATA-III 3.5" HDD, 6GB/s, 7200RPM, 64MB
CACHE
1st M.2 SSD Drive 256GB INTEL® 760p M.2 NVMe PCIe SSD (up to 3210MB/sR |
1315MB/sW)
Power Supply CORSAIR 650W TXm SERIESTM SEMI-MODULAR 80 PLUS® GOLD, ULTRA
QUIET
Processor Cooling Corsair H100x Hydro Series High Performance CPU Cooler
Wireless/Wired Networking WIRELESS INTEL® Wi-Fi 6 AX200 2,400Mbps/5GHz, 300Mbps/2.4GHz
PCI-E CARD + BT 5.0
USB/Thunderbolt Options MIN. 2 x USB 3.0 & 2 x USB 2.0 PORTS @ BACK PANEL + MIN. 2 FRONT
PORTS
Operating System Windows 10 Home 64 Bit - inc. Single Licence
That motherboard won’t support an AM5 7800X3D, as the 5600X is onthe older AM4 platform, so you’d need a new motherboard, new more powerful PSU, new DDR5 RAM, etc.
The fastest gaming CPU you could upgrade to on your current platform would be a 5700X3D (or a 5800X3D if you can find one). A GPU upgrade (to a 7800XT, 9070XT, 5070Ti tier) would require a PSU upgrade to a modern ATX3 PSU to protect yourself from the transient power spikes modern GPUs seem to produce.
Justyna
Ah! So if i want to make a significant upgrade, then I would need to change all the major parts. Would need to rethink my strategy here! Is there a point of making a small upgrade of the GPU/CPU that will work with my current motherboard and power supply? what could that be?
5700X3D/ 5800X3D and for GPU? and again, is there a point to it?
From a 6 core standard chip to an 8 core X3D chip even from the same generation would be a notable improvement on the CPU front.
That would unlock extra potential from a current gen GPU
All depends on your budget for this?
What make and model monitor are you using?
Depends where the bottleneck is.
If it’s the CPU, then the X3D parts perform much better.
If it’s the GPU, then you’re limited by the older 650w ATX2 PSU, but a 7700XT should be a big enough upgrade without requiring too much power.
You’d also probably get a little boost by getting a second SSD for game installs, and possibly a bigger boot SSD if it’s getting full as that will slow everything down.
….but as @BlessedSquirrel says above, it depends on budget.
Justyna
Thank you both!
I was thinking of dedicating around £1000
And yes, I need to change my monitor as well as I'm using my old office monitor (from covid times)^^
PSU's seem affordable (if compared to GPS). so I'm wondering if it would be better to make the upgrade. But the the mother board... AGH!
So the minimum would be: 5700X3D/ 5800X3D, 7700XT, SSD + some RAM
You may be able to use the PCS upgrade service, but here are some prices to compare…
5700X3D @ £233
AMD 7700XT @ £400
1TB Crucial P310 boot SSD @ £60
2TB Solidigm P41 Plus games SSD @ £110
Here’s a chart showing the relative, generational performance uplift of your 5600XT and the 7700XT…
Justyna
5700X3D @ £233
AMD 7700XT @ £400
Amazing! Thank you! Looks like a plan!
Is there a certain type of monitor I should be looking at to utilise this graphics card? Because at this point that will be my bottleneck ^^
