USB 3.0 help
lewishollings
I was recently thinking about buying an external hard drive which comes with a usb 3.0 cable, do you have to have a usb 3.0 port to work at it's full speed?
and how would you go about finding about whether you have a usb 3.0 port?
steaky360
Typically USB ports look blue when compared to normal USB 2.0 ports - just as a really quick check :)
USB 2.0 on left, USB 3.0 on right
To use your USB 3.0 external drive at full speed you would indeed need a USB 3.0 port though!
EDIT - glad you've got some :)
