vortex III display connections on rear of unit?
hargil
what can you connect to the Display port on the rear of the vortex
it has
1 x DVI-I OUT Port which i understand, i have a monitor with dvi input
and a hdmi out which i also understand
but what is
1 x Display Port
from the photo it looks almost usb ish!!!
it does not look like a 15 pin D-type RGB port
so what sort of cable do you plug into it and what is the format of the signals out
thanks
hargil
thanks, never seen one of these bofore
as long as it has hdmi out it will be fine, i was just curios.
vga out would have been more useful but not an issue
thanks for the info
