Unfortunately one of the screen hinges of my Vyper Series: 15.6" laptop is separated from the back lcd cover which I suspect is broken (because I could see some pieces of plastic on the screw. The screen is perfect, and I can still use the laptop (I guess the other one is getting a bit more pressure)
The laptop doesn´t have 2 and a half years yet. I think is still young for this kind of problem. My last laptop (a VAIO) was with me 10 years and never had this kind of problem and I believe I am quite carefull with my laptop...
I contacted tech support and after quite a few messages what I know:
My silver warranty covers just the labour part. Because I am not in the UK thats create a dilemma for me.
I can purchase just the piece and find someone to fix it for me here.(I don´t know if I could find the piece if not buying from PCS) maybe I could try it. I may risk the rest of the warranty if something goes wrong. Is this a delicate repair?
I can pay to send it and then they would evaluate and tell me the price. This could take 3 weeks plus the 6/8 days of the laptop journey...quite a long time
Someone has been in this situation?
I also feel that is a chasis fault, anyone has this hinge problem?
May be problematic for the other hinge let the laptop like that for a while?
I was searching in the forum to try to know my chasis and I found a lot of interesting information as well (the gaming center download so now I can regulate the keyboard light with the FN keys and other things I need to learn about the temperatures, maybe a fix for my WIFI also fails sometimes etc )
I have my laptop plugged almost all the time I use it (lot of hours) because the battery was lasting less dan 1 hour when I bought it and now less than 30 minutes. It is bad to have it plugged all the time? Is there any way to recalibrate it or those are miths?
Thanks!
Thanks!
