Hello, I bought a gaming pc on here around October 2020, it's still running well. However, I am looking for things to upgrade. My current Gpu is a GTX 1660 super, and my cpu is a ryzen 5 3600 6 core. I'm not sure how good the motherboard is but it is a Asus rog strix B450 F-gaming.
When I bought the pc I had a low budget, the pc costed around £852 at the time. I also, got a kinda low budget case and did no research into the case, which now I regret since doing research now It seems if I actually posted my spec when I bought it the case would not have been recommended as has poor air flow and loud fans. The 3 fans run at a constant speed and are connected to the pcu.
I'm not that great at pc technology and replacing things but have done a lot of research recently about how to replace gpu, cpu, fans, and cpu cooler.
So due to my case fans being loud I was also wondering if you could recommend me fans that I could replace them with, I have added no fans since I bought the pc so has the standard amount. So what fans would you recommend I should buy and replace them with, or do you think it's better for me to buy a completely new case, but not sure if I want to transfer everything over to the new case since I am no pc expert, and something could go wrong in the process.
And, what would do you think I should upgrade my cpu and gpu to. I don't want something that's super expensive, but something that is an improvement from what I have got. I was looking at Rryzen 7 and 9, as they don't seem to expensive but not sure. I was also looking at the rtx 3060 ti, but don't know if this is a major improvement or not. I am not planning on upgrading everything in one go, but slowly start to upgrade everything and improve my pc. Also, considering I have heard the 4000 series is coming soon idk if I should wait till then before buying and gpu as prices might fall, but still not sure.
I also have a few other questions sorry if these are dumb, I'm not great when it comes to pc upgrading and wiring. I see people with like rgb wires but not sure what they are called or what they are used for. I also see people with gpu that have lights and wasn't sure if you have to add them or if some gpu's have rgb built in.
I'm and also not 100% sure how to cable manage inside the pc and make everything look the best it can with no loose wires, It's fine rn as I have not touched the inside other than cleaning dust since I got the pc but feel like I will make the inside look bad when I start doing the wires by myself.
Thanks in advance.
Thanks in advance.
