Will this be OK
So this is my first gaming PC so i definitely don't want it blowing up. Does everything match, is there sufficient power, will the CPU/GPU work together. Specs are as follows:
GIGABYTE X570S AORUS ELITE AX : ATX (USB 3.2 Gen 1, PCIe 4.0, CrossFireX) - ARGB Ready!
16GB Corsair VENGEANCE DDR4 2400MHz (2 x 8GB)
12GB AMD RADEON™ RX 6700 XT - HDMI, DP - DX® 12
STANDARD AMD CPU COOLER
LED Lighting
50cm RGB LED Strip
Extra Case Fans
Monitor
IIYAMA G2740HSU-B1 27" Monitor
Keyboard & Mouse
PCS GK180 88-Key RGB Backlit Mechanical Keyboard (Red Switch)
JUNI0R
LED Lighting
50cm RGB LED Strip
Extra Case Fans
Monitor
Keyboard & Mouse
Heya! There's a couple of areas we could change here. We'll need some more info before we're able to assist however-
What's your budget? Does this budget include a monitor?
What will you be doing with the PC? Gaming? If so what games? Streaming? Editing of some sort?
I see there's a monitor in the spec, is this the monitor you plan to use with your build or will another one sit along side?
Would you be able to provide the full spec (including all the warranty and delivery info, it's all still important!) and green configurable link for this spec? It should be just below where you got this formatted text from!
Once we have this info, we'd be happy to proceed, thanks!
I plan on using this PC for all my gaming. I'll be playing games like Minecraft, Cyberpunk 2077 and Phasmophobia. I won't be streaming or editing. The monitor and keyboard should ideally be within my budget. My budget is £2000. The full specs are:
LED Lighting
50cm RGB LED Strip
Extra Case Fans
Monitor
Keyboard & Mouse
JUNI0R
LED Lighting
50cm RGB LED Strip
Extra Case Fans
Monitor
Keyboard & Mouse
From your spec, it looks like you're using the "home and office" configurator, I've switched over to the "Ryzen Extreme Computers" configurator as it gives us better and more up to date options. When it comes to your peripherals, the PC and monitor take you slightly over your 2K budget (by about £30) then I've excluded the keyboard for now.
When it comes to monitors themselves, you comfortably have the budget for a 1440p 144hz system and monitor which I'd highly recommend over 1080p. PCS doesn't have the best range of monitors, so I'd recommend going elsewhere for one. Our go to recommendations for this category are the Gigabyte M27Q, ASUS TUF VG27AQ and Dell S2721DGF which should all come in at about the £300.
AMD Ryzen 5 5600X Six Core CPU (3.7GHz-4.6GHz/35MB CACHE/AM4) Newer generation of AMD CPU, for gaming, it'll outperform the 3700X
ASUS® TUF GAMING B550-PLUS WiFi (DDR4, USB 3.2, 6Gb/s) - ARGB Ready! All the motherboard you'll need for the 5600X, this one has WiFi
16GB Corsair VENGEANCE DDR4 3200MHz (2 x 8GB) It's important to go for fast RAM with Ryzen, this 3200mhz kit should be ideal
8GB NVIDIA GEFORCE RTX 3060 Ti - HDMI, DP, LHR great 1440p 144hz GPU
500GB SAMSUNG 980 PRO M.2, PCIe NVMe (up to 6900MB/R, 5000MB/W) Significantly faster Boot SSD for Windows and applications
1TB INTEL® 670p M.2 NVMe PCIe SSD (up to 3500MB/sR | 2500MB/sW) Speedy secondary drive for games and applications
CORSAIR 850W RMx SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET Higher quality and wattage PSU to better cover for future upgrades
CoolerMaster Hyper 212 (120mm) Fan CPU Cooler Black Edition A well reviewed CPU cooler that will be ample for the 5600X, you could remove if you wanted to get the build back under the 2K budget
Windows 10 Home 64 Bit - inc. Single Licence [KUK-00001] I'd stick to W10 while W11 is in it's infancy and a bit buggy
NO ANTI-VIRUS SOFTWARE Windows defender is perfectly acceptable as an Anti-Virus
Price: £1,724.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/vpxzBr9Qxw/
Hi again, so I've ordered the PC and a monitor, do you have any good recommendations for mechanical keyboards and mouses.
Hi mate, it really depends on your budget. The Corsair K70 is a forum favourite "affordable" mechanical keyboard but the best of the best are Ducky if you don't mind splurging out
As for mice I personally like the Razer Deathadder, I've used this mouse for over 10 years and I'll likely never change to another. It's a perfect fit for me
MrWilson
From forum advice I ordered both the K70 and the Deathadder back in the summer. I can personally rate both of them highly :)
Another vote here for the K70, mouse wise I have the corsair M65 RGB Elite, so that everything can be synced up nicely in iCUE
I'm another with a K70, great keyboard.
Mousewise I have a deathadder on my laptop and a ROCCAT RAT 7 on my desktop which is OLD
RichLan564
It's absurd how many of us have a K70
I went left field with Keychron K8 TKL, Gateron Browns, hot swappable switches, RGB, Bluetooth or cabled, really nice board and should last a lifetime
I hate wired mice so went Logitech G703
