Will this graphics card work with a 4K UHD monitor? | PCSPECIALIST
jonbam
Hi
I purchased my pcspecialist computer on 13-01-2016
I have the following graphics card: 6GB NVIDIA GEFORCE GTX 980 Ti - DVI, HDMI, 3x DP - GeForce GTX VR Ready!
Will the card above work with a 4K UHD monitor?
thxs
Jonathan
Recluse
Hi
thxs
Jonathan
No, nowhere near powerful enough.
You’d need a 2080ti or 3070 as a minimum
jonbam
I have a ASUS® Z170-E: ATX, LG1151, USB 3.1, SATA 6GBs
Is it possible to upgrade the graphics card, what would it cost for a new card?
thxs
Jonathan
Recluse
thxs
Jonathan
Can you post your full specs from the order page? The motherboard has no relation to GPU, it’s more the PSU and case.
jonbam
COOLERMASTER HAF-X FULL TOWER GAMING CASE
Intel® Core™ i7 Quad Core Processor i7-6700 (3.4GHz) 8MB Cache
MotherboardASUS® Z170-E: ATX, LG1151, USB 3.1, SATA 6GBs
Change to: 16GB HyperX FURY DDR4 2133MHz (2 x 8GB)
Graphics Card6GB NVIDIA GEFORCE GTX 980 Ti - DVI, HDMI, 3x DP - GeForce GTX VR Ready!
2nd Graphics CardNONE
3rd Graphics CardNONE
1st Storage Drive2TB WD BLACK 3.5" WD2003FZEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
Partitions: 1000GB, 1000GB
2nd Storage DriveNONE
3rd Storage DriveNONE
4th Storage DriveNONE
1st M.2 SSD Drive512GB SAMSUNG SM951 M.2, PCIe NVMe (up to 2150MB/R, 1550MB/W)
Partitions: 512GB
1st PCI-E SSD DriveNONE
2nd PCI-E SSD DriveNONE
RAIDNONE
DVD/BLU-RAY Drive24x DUAL LAYER DVD WRITER ±R/±RW/RAM
2nd DVD/BLU-RAY DriveNONE
External Hard DriveNONE
Memory Card ReaderNONE
Power SupplyCORSAIR 650W CS SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
Processor CoolingSuper Quiet Titan DragonFly Heatpipe Intel CPU Cooler
Change to: CoolerMaster Hyper 212 EVO (120mm) Fan CPU Cooler
LED LightingNONE
Fan ControllerNONE
Extra Case FansNONE
Wireless/Wired Networking10/100/1000 GIGABIT LAN PORT (Wi-Fi NOT INCLUDED)
Wireless Router/HomePlugsNONE
USB/Thunderbolt Options2 PORT (2 x TYPE A) USB 3.1 PCI-E CARD + STANDARD USB PORTS
Recluse
The case is fine but you’d have to replace the PSU with a 850w RMx, then I’d get a 3080 for around £800
