Yeah, what is that keyboard?cool keyboard as well
Did your CPU clocks rise a bit once the fans were in?
That case is really well done, I love how the rgb comes through the mesh.
Did not have the chance to run benchmarks yet, as it's my first time having RGB on a case and I was overwhelmed by the amount of options that iCue gives you.Yeah, what is that keyboard?
That's incredible value for £50 plus being hot swappable, that's really unusual at such a low price.It's a cheap chinese brand, but I was impressed by the quality of the keyboard overall for the price (£50). The software is not great as Razer Chroma's, but at least it has some way to customize the RGB. It's also hot swappable, so I did replace most of the switches and did some mods like adding black GMMK keycaps (in French, which I bought at amazon UK for £5 - and no, I'm not French nor do I speak French) and some sound dampening foam.
I know what it is in context to our pharmaceutical industry - and if you wanted to bind a specific 'stuff' to the surface of the keyboard to make it resistant to another 'stuff', but not sure why you'd specifically want random 'stuff' to stick to your keyboard.
The results are in... and it was the first time that I got a "Great" result in Firestrike when compared to other people's scores (even got a steam badge for it), meaning it went from 37,243 to 37,885.Yeah, what is that keyboard?
That's not bad at all for a SFF build!The results are in... and it was the first time that I got a "Great" result in Firestrike when compared to other people's scores (even got a steam badge for it), meaning it went from 37,243 to 37,885.
The CPU did indeed clock higher on average (4.75GHz x 4.8 GHz), even though it was 1°C higher on both average and maximum temperatures. But that 1°C more on max temperature means that it reached 71°, which I'm still perfectly happy with. Could even tweak some fan curves if needed.
However, as expected, the major gains where on the GPU. The average clocks were actually a bit lower (2.84GHz x 2.81Ghz), but it reached a higher clock than before (2.85GHz x 2.865GHz) and for various periods where the GPU was pushed to its limits by the test. And all that also dropping the maximum temperature by 6°, reaching only a maximum of 58° during the test. The average temperature also dropped by 3° 🥳
