Need advice on first PC build.
kokoykno
I'm really interested in getting my first PC. I want to be able to play loads of games and stream but the games require quite a powerful PC so please help. Ideally I want to be able to have the capacity to run games like Gray Zone Warfare etc at a great quality, but also be able to play COD and FIFA NBA2K etc and stream comfortably. i'll post the build i've started with, but i've literally no idea what's good and what isn't. Any help and suggestions is greatly appreciated. My budget is 2.5k hard cap, but preferably nearer to 1-1.5k.
PCS PRISM TG WHITE ARGB MID TOWER CASE
AMD Ryzen 5 7500F Six Core CPU (3.7GHz-5.0GHz/38MB CACHE/AM5)
GIGABYTE B650M DS3H (mATX, AM5, DDR5, PCIe 4.0)
64GB PCS PRO DDR5 4800MHz (2 x 32GB)
20GB AMD RADEON™ RX 7900 XT - HDMI, DP - DX® 12
Graphics Card Support Bracket
1TB PCS PCIe M.2 SSD (3500 MB/R, 3200 MB/W)
ONBOARD 2.5Gbe LAN PORT
Microsoft® Edge
Monitor
AOC 27" 27B2AM - 1920 x 1080,4MS, HDMI
Keyboard & Mouse
Tecware Phantom RGB 105-Key Backlit Mechanical Keyboard (Brown Switch)
Keyboard & Mouse
ASUS TUF Gaming M4 Air
Standard Build - Approximately 3 to 5 working days
Price: £1,981.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/84ae!!FuAm/
sck451
I'd look at a 1440p IPS gaming monitor. The outstanding value option is the AOC Q27G4X, which is £220. It would then match a build like this, which would bring the overall cost to precisely £2k, very close to your build above.
FRACTAL FOCUS 2 ARGB GAMING CASE (BLACK) Much better case
AMD Ryzen 7 7700 Eight Core CPU (3.8GHz-5.3GHz/40MB CACHE/AM5) Much better CPU
ASUS® TUF GAMING B650-PLUS WIFI (AM5, DDR5, PCIe 4.0, Wi-Fi 6) Much better motherboard
32GB Corsair VENGEANCE DDR5 6000MHz (2 x 16GB) Much better RAM
16GB AMD RADEON™ RX 7800 XT GAMING - HDMI, DP - DX® 12 Slight downgrade on the graphics card, but a much better match for the monitor
512GB SOLIDIGM P44 PRO GEN 4 M.2 NVMe PCIe SSD (up to 7000MB/sR, 4700MB/sW) Boot drive
1TB SOLIDIGM P41+ GEN 4 M.2 NVMe PCIe SSD (up to 4125MB/sR, 2950MB/sW) Games drive (2TB would be ideal)
DeepCool AK620 ZERO DARK High-Performance Dual Tower CPU Cooler A really good cooler
Microsoft® Edge
Keyboard & Mouse
Keyboard & Mouse
Price: £1,780.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/Y2PyK6xMe8/
kokoykno
Microsoft® Edge
Keyboard & Mouse
Keyboard & Mouse
Thank you so much. In your opinion, do you think what i've built here will do well to run a game with such heavy requirements as Gray Zone Warfare?
Well, the the build exceeds what is required for the official 'recommended' specs:
RECOMMENDED SYSTEM REQUIREMENTS:​
  • Requires a 64-bit processor and operating system
  • OS: Windows® 10 64 Bit (latest update) / Windows® 11 64 Bit (latest update)
  • Storage: SSD with 40 GB available space
  • Network: Broadband Internet connection
  • CPU: Intel® Core™ i7-9700K / AMD Ryzen™ 5 3600X Memory: 32 GB RAM
  • RAM: 32 GB
  • GPU: NVIDIA® GeForce® RTX 3070 Ti / AMD Radeon™ RX 6800 DirectX: Version 12
But, as with most system requirements, they don't specify what resolution/quality these are for. So we don't know if 'recommended' is intended for 60FPS @ 1080p or 144FPS at 4k.
However, from the reviews I've seen, it's another case of a really un-optimised game being released in early-access with hopes that they'll optimise it as & when they get more cash from punters buying it.
Keeping the 'early-access' status in mind, this YouTuber, playing at 1440p with an 7800XT using Epic settings, they're seeing 60+FPS (and peaks of over 80fps).
Whether it's wise to play a fast-paced MMORPG at Epic settings is debatable though, so if you play at the more normal High settings with FSR or FG on, then you're going to see higher FPS than that.
kokoykno
Thank you, this has been really helpful!
