redorblue89
Specs are below, I received it last week and only recently tried putting it to sleep, it seems to power down fine but then when i try to wake it from sleep the monitor says check signal connection but the desktop seems to be powering up. I have tried re-installing the nvidia graphic drivers (clean re-install), updated the mobo bios, tried different connection types to the monitor (usually use hdmi to hdmi), tried connecting to my tv. Nothing has worked.
Also once i do manually hold the power button down to shut it down then start it up again the screen starts working again and it resumes windows but takes a very long time to boot and then runs slow for a very long time.
One last thing,generally how quick do you think my boot times should be? It doesn't feel like they are as quick as I'd like considering the system spec.
Win 7 64-bit professional
Asus P8P67 Pro
i7 2600K OC'd (Max4.8GHz clock with turbo boost)
GTX 580 1.5GB
8GB 1600mhz Ram
1TB SATA 7200rmp hard drive
Corsair TX 750W
Asus P8P67 Pro
GTX 580 1.5GB
8GB 1600mhz Ram
Corsair TX 750W
