I've just got a new PC with dual 7970 cards in it - the problem I have is that with the standard settings the GPU gets very hot when running games (WoW and Witcher 2 so far) - it gets up to 80+C and generally crashes thereafter.
The problem seems to be that with the fans set to auto the Catalyst Control Centre never seems to drive the fans beyond about 30% of max which just isn't enough. If I manually set the fans to 40-45% then the problem goes away (GPU temps then drop down to about 70%). It's just a little inconvenient to have to do this.
Does anyone know if there is a way to change the auto settings for the fans? Surely the auto setting ought to push the fans hard enough to prevent the card from overheating?
