Help With Gaming pc Specs.
Bet
I was wrong, by the way, sorry. The Dell monitor you linked is the very latest and greatest. It's absolutely the one you should go for if you can afford it.
My apologies: my only excuse is that monitor names are unbelievably stupid.
Ikr I was looking through them and was getting so confused cuz there all basically called the same
Ah, I didn't check it, yeah, it's one of the latest, it's a really good option
Bet
Okay then my last check in, these are the specs.
ASUS® TUF GAMING X670E-PLUS WIFI (AM5, DDR5, PCIe 5.0, Wi-Fi 6E)
16GB NVIDIA GEFORCE RTX 4080 SUPER - HDMI, DP, LHR
Graphics Card Support Bracket
2TB CORSAIR CORE XT MP600 NVMe PCIe M.2 SSD (up to 5000 MB/R, 4400 MB/W)
CORSAIR ICUE LINK H150i RGB HIGH PERFORMANCE CPU COOLER
Extra Case Fans
4 x Corsair ICUE LINK QX120 RGB PWM Fan + Controller Kit
ONBOARD 2.5Gbe LAN PORT
Surge Protection
8 Socket 2m Surge Protector
Price: £2,800.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/KtRKSwJxqX/
Bet
Okay I ordered the monitor, will get it on the 24th, gonna order pc asoon as 4080 is in stock
Bet
Just some last check ups, for the Ram should I get the fastest one I can or stick with the 6000mghz
As in the config suggested.
As with all things, the highest doesn't mean best for your use case. All components are balanced for your use case and budget.
MOAR doesn't = BETTERER
Over 6000Mhz for gaming = 0 different except to your wallet
Bet
Can't be Serious lol
Bet
Back again to bother you, I've settled with the specs you gave me not gonna try change them now, just a question tho, do you think it'll be able to do most games at 4k?
Also I know you don't work here, but if you could give a rough guess how long does it take from ordering to receiving the PC, just so I can have a rough guess to when to order so it arrives around the same time as my monitor
As an owner of the Razer Deathadder, they are superb mice. That one is incredible value for a 30k sensor!
This has already been discussed numerous times. I suggest reading back over the thread.
It tells you when you put through the order, not something we can tell you. But remember they're estimates, there's no way for them to give you a specific date. And also remember all times quoted are working days ie monday to friday not including bank holidays.
Bet
Great stuff! I'll get that mouse then. Thanks Again
Bet
Okay Guys Many Thanks for all the help this is the setup ima go with, just made some minor adjustments like a lcd cpu cooler and argb, also changed the Power supply from 1200W to 1000W (do you think it'll be better to get 1200W for future proofing?). Gonna Order Tommorow hopefully
256GB PCS PCIe M.2 SSD (3200 MB/R, 2700 MB/W)
2TB SAMSUNG 990 EVO M.2, PCIe 4.0 & 5.0 NVMe (up to 5000MB/R, 4200MB/W)
CORSAIR iCUE H150i ELITE LCD XT RGB CPU Cooler
LED Lighting
2 x 50cm ARGB LED Strip
Extra Case Fans
Surge Protection
Price: £2,850.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/Zm60ArXyR8/
There is a reason the 1200w was specced.
Why have you changed the primary drive to a basic one? Seems a very odd thing to do, that will not be suitable.
Samsung 990 as the secondary drive as well is just throwing money down the drain for no benefit.
Remove Norton
You've also gone back to your mismatched AIO & fan config - so you've got iCUE Link and normal iCUE components...which means 2 different controllers and much more wiring.
Bet
Oh my bad didn't mean to do that was just messing around thanks for pointing that out
Bet
Okay I have Ordered the following:
Promotional Item
2nd M.2 SSD Drive
DVD/BLU-RAY Drive
NOT REQUIRED
CORSAIR 1200W RMx SHIFT SERIES™ MODULAR 80 PLUS GOLD, ULTRA QUIET
LED Lighting
Extra Case Fans
NOT REQUIRED
Surge Protection
Cable Management
3 x PCS 1.5M Zip Cable Tidy - Professional Cable Management
Welcome Book
PCSpecialist Welcome Book
Any Mistakes I made pls let me know lol
