Problem AIO
AlexGeno
Good morning guys,
I just got my new AIO. While using the computer, it turns itself off and on again by itself. What can I do ?! I only know that it could be a problem with the power source.
Good morning guys,
Is this a PCSpecialist PC? Can you post your full specs?
AlexGeno
Yes , is a PCSpecialist AIO .
AlexGeno
Ohh , yeah sorry . This is it .
When it shuts down, does it give a blue screen error or just restart?
can you install hwmonitor and give us the temp when idle and under load?
AlexGeno
No blue screen error , just restart.
  • HWMonitoriddle.txt
  • HWMonitorLoad.txt
Thanks for that, your temps look absolutely fine which is the first thing to check with symptoms like this.
They're actually rediculously low to the point I can't believe they're on an AIO!
I would give PCS a call tomorrow.
It's impossible to tell and it would be a lot quicker to troubleshoot with them remotely than over a forum.
