Hi I wonder whether anyone can help me with the boot up issue I have been having for 5 months now.
I've had the pc for a year and 4 days and although I've been in touch with PCS many many times and they've tried various things to try and resolve the issue (new hard drive, change in BIOS settings, updating drivers etc) I'm still having the same problems. It's taken me approx. 35 attempts to start my pc this morning and although all the fans are running and I get the start up bleep the following happens:
(a) Asus Motherboard blue screen briefly flashes up (for less than a second and if you try to get into bios you will see the bios screen briefly flash up but you cannot enter that area)
(b) Atheros Boot Agent then flashes up
(c) Either the Windows Error Recovery screen will flash up or the Windows start menu flashes up but I’m unable to log into the blue screen and the screen remains blank.
(d) I then have to power off and on again and repeat the above exercise until the Atheros Boot Agent stays on the screen and then it will go to the Windows Error Recovery screen from where I can either try and repair or start windows normally.
I've checked the forum and it seems that a few people are experiencing similar problems to myself but I can't see any fixes for this issue.
Any advice will be gratefully received.
Thanks.
LittleT
My PC spec is:
Processor (CPU) - Intel® Core™2 Quad Q8300 (2.50GHz) 1333MHz FSB/4MB Cache
Memory (RAM) - 4GB CORSAIR XMS2 DUAL-DDR2 800MHz - LIFETIME WARRANTY
Motherboard - ASUS® P5QPL-AM: DDR2, S-ATA II, 1 x PCI-E x16, 2 PCI
Operating System - Genuine Windows Vista™ Home Premium 32-bit + Windows 7 Upgrade
USB Options 6 x USB 2.0 PORTS (4 REAR + 2 FRONT) AS STANDARD
Memory - 1st Hard Disk 250GB SERIAL ATA 3-Gb/s HARD DRIVE WITH 8MB CACHE (7,200rpm)
1st DVD/BLU-RAY Drive 22x DUAL LAYER DVD WRITER ±R/±RW/RAM
Graphics Card 1GB ATI RADEON™ HD 4650 PCI EXPRESS
Sound Card ONBOARD 8 CHANNEL (7.1) HIGH DEF AUDIO (AS STANDARD)
Network Facilities WIRELESS N 300Mbps PCI CARD (£16)
Memory Card Reader INTERNAL 52 IN 1 CARD READER (READS XD, MS, CF, SD, etc)
Case STYLISH PIANO BLACK FUSION CASE + 2 FRONT USB
Power Supply & Case Cooling 450W Quiet Dual Rail PSU + 120mm Case Fan (£25)
Processor Cooling STANDARD CPU COOLER
Thanks.
LittleT
My PC spec is:
