£3000 budget. High FPS and good cooling/low temp
RyanAl18
I'm looking for a PC that can give me high fps in most AAA games but low temperature/good cooling is important also.
Case CORSAIR iCUE 465X RGB GAMING CASE
Processor (CPU)Intel® Core™ i9 Eight-Core Processor i9-11900K (3.5GHz) 16MB Cache
MotherboardASUS® TUF GAMING Z590-PLUS WIFI (LGA1200, USB 3.2, PCIe 4.0) - ARGB Ready
Memory (RAM)32GB Corsair VENGEANCE RGB PRO DDR4 3200MHz (4 x 8GB)
Graphics Card8GB NVIDIA GEFORCE RTX 3070 Ti - HDMI, DP
1st Storage Drive2TB SEAGATE BARRACUDA SATA-III 3.5" HDD, 6GB/s, 7200RPM, 256MB CACHE
1st M.2 SSD Drive500GB SAMSUNG 980 PRO M.2, PCIe NVMe (up to 6900MB/R, 5000MB/W)
DVD/BLU-RAY DriveNOT REQUIRED
Power SupplyCORSAIR 750W RMx SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
Processor CoolingPCS FrostFlow 240 Series RGB High Performance Liquid Cooler
Wireless Network CardNOT REQUIRED
USB/Thunderbolt OptionsMIN. 2 x USB 3.0 & 2 x USB 2.0 PORTS @ BACK PANEL + MIN. 2 FRONT
MonitorAOC 21.5" E2270SWHN LED Monitor. 1920 x 1080, 5MS
Any improvements? I'd really appreciate any feedback.
MrWilson
Godlike
In all honesty, I would recommend cancelling this build and letting us help you spec out a new one.
The 11900k is the polar opposite of a cool CPU, you would be much better placed to go for an AMD build.
If you’ve ordered this less than 2 weeks ago I would recommend cancelling and then if you could please order the following it’ll help us spec you something more appropriate:
What is your budget?
What are you using the PC for besides gaming? e.g streaming, editing, office work etc
Are you happy to go elsewhere for a monitor? PCS don’t have the best monitor selection unfortunately, you can usually get a better deal if you shop around a little. What would be your combined PC and monitor budget?
Hi @RyanAl18 - I’ve just amalgamated your recent post into your ‘check this spec’ thread as knowing the parts of the build is relevant to the delivery time.
You’d probably be looking around 30-40 days for your current spec, the GPU being the high value item.
But you did say you were looking for feedback on your original post and you got some possibly unwelcome but wise words from @MrWilson. If you’d like any advice, please get back to us with the info he suggested providing and someone will be able to come up with an improved build for you 👍
RyanAl18
I already ordered but with the AMD 5900X and upgraded the processor cooler. My new changed build is similar to yours. Max budget including monitor is £3000 and using this for programming and gaming.
Processor (CPU)AMD Ryzen 9 5900X 12 Core CPU (3.7GHz-4.8GHz/70MB CACHE/AM4)
MotherboardASUS® PRIME B550-PLUS (DDR4, USB 3.2, 6Gb/s) - ARGB Ready!
Change to: ASUS® TUF GAMING B550-PLUS (DDR4, USB 3.2, 6Gb/s) - ARGB Ready!
Memory (RAM)32GB Corsair VENGEANCE RGB PRO DDR4 3600MHz (2 x 16GB)
Change to: CORSAIR 1000W RMx SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
Processor CoolingPCS FrostFlow 240 Series RGB High Performance Liquid Cooler (AMD)
Change to: Corsair H100i RGB PRO XT Hydro Series High Performance CPU Cooler
Change to: STANDARD THERMAL PASTE FOR SUFFICIENT COOLING
LED Lighting2x 50cm ARGB LED Strip
Wireless Network CardWIRELESS 802.11N 300Mbps/2.4GHz PCI-E CARD
MonitorMSI 27" Optix G27C6 - 1920 x 1080, 1MS, 165Hz
Change to: MSI 27" Optix G271 - 1920 x 1080, 1MS, 144Hz
Monitor Cables1 x 2 METRE HDMI (M) to DVI (M)
Completely agree with wilson
only issue i can see if the 1080p 144hz monitor would be bottlenecked by the 3070ti
MrWilson
Godlike
Agree with the above posts regarding the STRIX X570 motherboard and the AX200 wireless card.
The 3070ti is also massive overkill for a 1080p monitor. If you take the monitor out of your order how much of your £3000 budget do you have left? You should definitely be targeting at least 1440p, decent options there start around the £300 mark, or alternatively you can rock an Ultrawide like the AOC display I have for around the £450 mark.
RyanAl18
Thanks I made the changes. The monitor I went for is PCS GD27 27" GAMING MONITOR - 1440p, IPS, 165Hz
MrWilson
Godlike
This is a fairly new offering from PCS, and we don’t know very much about it, I haven’t been able to find any reviews online. I am much more confident recommending monitors that I or other forum regulars have experience with e.g Samsung G5, G9 or my own AOC monitor; plus monitors that have positive reviews from reputable sources such as R8tings or Hardware Unboxed.
If you are dead set on getting a 1440p monitor from PCS this is probably the one to go for. If you do go down this route I would definitely be interested to know how you get on with this display as if it’s a good panel it’s a great value purchase.
RyanAl18
Yep, doing a review on the monitor and on the whole system is my plan.
RyanAl18
Total cost including the monitor is £2744.
